Hello,
i tried to use the ETHERNET and MQTT library in connection with timer interrupts.
The programm works and stops after a while, no timer interrupt is generated anymore. What is the reason for disabling the interrupts?
Attached the programm:
#include <Ethernet.h>
#include <MQTT.h>
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
byte ip[] = {192, 168, 1, 177}; // <- change to match your network
EthernetClient net;
MQTTClient client;
unsigned long timecount = 0;
void connect() {
Serial.print("connecting...");
while (!client.connect("arduino", "public", "public")) {
Serial.print(".");
Serial.println("\nconnected!");
client.subscribe("/hello");
// client.unsubscribe("/hello");
void messageReceived(String &topic, String &payload) {
Serial.println("incoming: " + topic + " - " + payload);
// Note: Do not use the client in the callback to publish, subscribe or
// unsubscribe as it may cause deadlocks when other things arrive while
// sending and receiving acknowledgments. Instead, change a global variable,
// or push to a queue and handle it in the loop after calling `client.loop()`.
cli();
/* // Pin change IRQ control register
// X X X X X PCIE2 PCIE1 PCIE0
PCICR |= 0b00000100;
// Pin Change Mask Register 0
// PCINT7 PCINT6 PCINT5 PCINT4 PCINT3 PCINT2 PCINT1 PCINT0
PCMSK0 |= 0b00000000;
// PCINT15 PCINT14 PCINT13 PCINT12 PCINT11 PCINT10 PCINT9 PCINT8
PCMSK1 |= 0b00000000;
// PCINT23 PCINT22 PCINT21 PCINT20 PCINT19 PCINT18 PCINT17 PCINT16
PCMSK2 |= 0b00001111;
DDRK = 0x00; // Port K as INPUT (1 = OUTPUT)
PORTK = 0xFF; // pullup enable
//These are for Timer1
#define PRESCALE0_1 1u
#define PRESCALE0_8 2u
#define PRESCALE0_64 3u
#define PRESCALE0_256 4u
#define PRESCALE0_1024 5u
//set 16bit timer5 interrupt at 2kHz ISR(TIMER5_COMPA_vect)
TCCR4A = 0; // set entire TCCR2A register to 0
TCCR4B = 0; // same for TCCR2B
TCNT4 = 0; //initialize counter value to 0
// set compare match register for 1ms
OCR4A = 0x0800;
// turn on CTC mode
TCCR4B |= (1 << WGM42);
TCCR4B |= PRESCALE0_8;
// enable timer compare interrupt
TIMSK4 |= (1 << OCIE4A);
//set 16bit Timer1 PhaseCorrect-PWM
TCCR1A = 0u;
TCCR1B = 0u;
TCCR1A |= (1 << WGM11)|(1 << COM1A1);
TCCR1B |= (1 << WGM13)|(1 << WGM12);
OCR1A = 120u;
ICR1 = 256u;
TCCR1B |= PRESCALE0_64;
sei();//allow interrupts
Serial.println("Ethernet connect");
Ethernet.begin(mac, ip);
client.begin("192.168.1.120", net);
client.onMessage(messageReceived);
connect();
//wdt_enable(WDTO_1S);
//timer4 interrupt 2kHz
ISR(TIMER4_COMPA_vect)
// publish a message roughly every second.
timecount++;
if ( timecount > 2000)
Serial.println("Timer ready ...");
client.publish("/hello", "world");
timecount = 0u;
client.loop();
if (!client.connected()) {
connect();
Kind regards
Maxl
