Timer interrupts - which library to use and why?
Hello,
I've been trying to implement a non-blocking function and i discovered the use of millis instead of delays and then i learned that interrupts or rather, timer interrupts offer an even better solution.
However, in my research, i found that some tutorials are using TimerOne.h and others use MsTimer2.h and i'm confused about which library to use? Which one is better? How do i choose the correct Timer library?
I found this page and it even mentions Timer3?? Arduino Playground - Timer1
DryRun:
To what problem?
This excellent tutorial uses no timer libraries.
TimerOne is the best place to start. But maybe your problem has a better solution.
Interrupts appear to be poorly-supported on Arduinos because they simply aren't necessary for you to play with in 98% of all Arduino programs. I have many large programs which have tight timing requirements and I don't use interrupts outside of standard libraries (eg. analogRead() uses an interrupt but you never need to know this when you are programming.)
