How can I trigger a timer interrupt to, say, go off every 10 seconds? I know I can make and external interrupt on pins 2+3, but can I do software interrupts like this? Or will I need a 555 timer in astable mode?
Processor? Clock speed?
baum:
Use http://www.arduino.cc/playground/Main/MsTimer2
Lefty
I just want to have an interrupt triggered every x seconds, which will then run a specified function, just like in attachIntterupt().
Sorry lefty... I posted while you posted.
Thanks for that! It's exactly what I had in mind. So it has a min. resolution of 1 ms?
Dont know about timer2 resolution, but if you dont think you are able to program your own timed event interrupt then you can "cheat" by manually change the code in MsTimer2.cpp to fit your needs with a suitable program like "source editor".
...change the code in MsTimer2.cpp to fit your needs ...
Not exactly. That's a good idea for short delays but for his needs he will have to use the interrupt to update a software counter and use that counter to determine when to run his specified function. I think he already figured this out.
Don
Yep, the time variable is a long, so max timed interrupt is like 55 days or so. I used it my 5x5x5 led cube to generate 2msec interrupts. Worked great.
Lefty
I find aikoevents to be a really simple way of making things happen at regular intervals- regardless of how long those particular events take or how long the rest of your program takes to loop. I was using before a messy code filled with millis() and interrupts to determine how long each event/iteration took, then adding times together to do one simple thing- which is repeat a task reliably at the same interval. It was impossible to get accuracy- and not to mention made the code a mess.
Simple=good 8)
