Hello,
While using the Arduino Mega2560 Rev3, I encountered a problem in which I was attempting to control pins 44,45 using analogWrite to obtain PWM output while simultaneously using the Servo library, which changed all of the PWM pin timings and caused those pins 44,45 to stop operating normally.
I need pins 44,45 to work at 490 Hz. I tried those methods and still couldn't find a solution:
- reset the clock and timing on the program manually for those 44,45 pins after setting up the servo library
#include <Wire.h>
#include <VL53L0X.h>
#include <Servo.h>
const int yawServoPin = 9;
const int pitchServoPin = 10;
Servo yawServo;
Servo pitchServo;
VL53L0X sensor;
// Motor control pins
const int leftMotorForwardPin = 49;
const int leftMotorBackwardPin = 47;
const int rightMotorForwardPin = 48;
const int rightMotorBackwardPin = 46;
const int rightMotorEPin = 44;
const int leftMotorEPin = 45;
int Speed = 50;
const int leftLedPin = 5;
const int rightLedPin = 6;
// Laser measurement settings
const int pitchAngle = 35;
const int opening = 180;
const int timming = 400;
const int steps = 2;
const int laserDistanceDiff = 30;
int referenceMeasurements[steps];
// Uncomment this line to use long range mode. This
// increases the sensitivity of the sensor and extends its
// potential range, but increases the likelihood of getting
// an inaccurate reading because of reflections from objects
// other than the intended target. It works best in dark
// conditions.
//#define LONG_RANGE
// Uncomment ONE of these two lines to get
// - higher speed at the cost of lower accuracy OR
// - higher accuracy at the cost of lower speed
//#define HIGH_SPEED
//#define HIGH_ACCURACY
void moveForward() {
// Move the robot forward
Serial.println("Moving forward...");
digitalWrite(leftMotorForwardPin, HIGH);
digitalWrite(leftMotorBackwardPin, LOW);
digitalWrite(rightMotorForwardPin, HIGH);
digitalWrite(rightMotorBackwardPin, LOW);
analogWrite(rightMotorEPin, 2 * Speed);
analogWrite(leftMotorEPin, 2 * Speed);
analogWrite(rightLedPin, 2 * Speed);
analogWrite(leftLedPin, 2 * Speed);
Wire.begin();
// Attach servos
yawServo.attach(yawServoPin);
yawServo.write(0);
// Stop Timer5
TCCR5A = 0;
TCCR5B = 0;
TCNT5 = 0;
// Set Timer5 to Phase Correct PWM mode (the default mode for Arduino)
TCCR5A = _BV(WGM50) | _BV(COM5C1) | _BV(COM5B1);
TCCR5B = _BV(WGM52) | _BV(CS51); // Prescaler set to 8
// The default TOP value for 8-bit resolution (255)
OCR5C = 0; // PWM value for pin 44 (start at 0)
OCR5B = 0; // PWM value for pin 45 (start at 0)
sensor.setTimeout(500);
if (!sensor.init())
Serial.println("Failed to detect and initialize sensor!");
while (1) {}
#if defined LONG_RANGE
// lower the return signal rate limit (default is 0.25 MCPS)
sensor.setSignalRateLimit(0.1);
// increase laser pulse periods (defaults are 14 and 10 PCLKs)
sensor.setVcselPulsePeriod(VL53L0X::VcselPeriodPreRange, 18);
sensor.setVcselPulsePeriod(VL53L0X::VcselPeriodFinalRange, 14);
#endif
#if defined HIGH_SPEED
// reduce timing budget to 20 ms (default is about 33 ms)
sensor.setMeasurementTimingBudget(20000);
#elif defined HIGH_ACCURACY
// increase timing budget to 200 ms
sensor.setMeasurementTimingBudget(200000);
#endif
for (int i = 0; i < steps; i++) {
yawServo.write(i * (opening / (steps - 1)));
delay(timming);
referenceMeasurements[i] = sensor.readRangeSingleMillimeters();
if (sensor.timeoutOccurred()) { Serial.print(" TIMEOUT"); }
Serial.print("Reference measurement at step ");
Serial.print(i);
Serial.print(" Distance (mm): ");
Serial.println(referenceMeasurements[i]);
moveForward();
delay(timming);
- Changing the Servo library for timer 5 to it will not make any change on timer 5 group (which I may have not done properly)
Servo.cpp - Interrupt driven Servo library for Arduino using 16 bit timers- Version 2
Copyright (c) 2009 Michael Margolis. All right reserved.
This library is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 2.1 of the License, or (at your option) any later version.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public
License along with this library; if not, write to the Free Software
Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
#if defined(ARDUINO_ARCH_AVR)
#include <avr/interrupt.h>
#include <Arduino.h>
#include "Servo.h"
#define usToTicks(_us) (( clockCyclesPerMicrosecond()* _us) / 8) // converts microseconds to tick (assumes prescale of 8) // 12 Aug 2009
#define ticksToUs(_ticks) (( (unsigned)_ticks * 8)/ clockCyclesPerMicrosecond() ) // converts from ticks back to microseconds
#define TRIM_DURATION 2 // compensation ticks to trim adjust for digitalWrite delays // 12 August 2009
//#define NBR_TIMERS (MAX_SERVOS / SERVOS_PER_TIMER)
static servo_t servos[MAX_SERVOS]; // static array of servo structures
static volatile int8_t Channel[_Nbr_16timers ]; // counter for the servo being pulsed for each timer (or -1 if refresh interval)
uint8_t ServoCount = 0; // the total number of attached servos
// convenience macros
#define SERVO_INDEX_TO_TIMER(_servo_nbr) ((timer16_Sequence_t)(_servo_nbr / SERVOS_PER_TIMER)) // returns the timer controlling this servo
#define SERVO_INDEX_TO_CHANNEL(_servo_nbr) (_servo_nbr % SERVOS_PER_TIMER) // returns the index of the servo on this timer
#define SERVO_INDEX(_timer,_channel) ((_timer*SERVOS_PER_TIMER) + _channel) // macro to access servo index by timer and channel
#define SERVO(_timer,_channel) (servos[SERVO_INDEX(_timer,_channel)]) // macro to access servo class by timer and channel
#define SERVO_MIN() (MIN_PULSE_WIDTH - this->min * 4) // minimum value in us for this servo
#define SERVO_MAX() (MAX_PULSE_WIDTH - this->max * 4) // maximum value in us for this servo
/************ static functions common to all instances ***********************/
static inline void handle_interrupts(timer16_Sequence_t timer, volatile uint16_t *TCNTn, volatile uint16_t* OCRnA)
if( Channel[timer] < 0 )
*TCNTn = 0; // channel set to -1 indicated that refresh interval completed so reset the timer
else{
if( SERVO_INDEX(timer,Channel[timer]) < ServoCount && SERVO(timer,Channel[timer]).Pin.isActive == true )
digitalWrite( SERVO(timer,Channel[timer]).Pin.nbr,LOW); // pulse this channel low if activated
Channel[timer]++; // increment to the next channel
if( SERVO_INDEX(timer,Channel[timer]) < ServoCount && Channel[timer] < SERVOS_PER_TIMER) {
*OCRnA = *TCNTn + SERVO(timer,Channel[timer]).ticks;
if(SERVO(timer,Channel[timer]).Pin.isActive == true) // check if activated
digitalWrite( SERVO(timer,Channel[timer]).Pin.nbr,HIGH); // its an active channel so pulse it high
else {
// finished all channels so wait for the refresh period to expire before starting over
if( ((unsigned)*TCNTn) + 4 < usToTicks(REFRESH_INTERVAL) ) // allow a few ticks to ensure the next OCR1A not missed
*OCRnA = (unsigned int)usToTicks(REFRESH_INTERVAL);
*OCRnA = *TCNTn + 4; // at least REFRESH_INTERVAL has elapsed
Channel[timer] = -1; // this will get incremented at the end of the refresh period to start again at the first channel
#ifndef WIRING // Wiring pre-defines signal handlers so don't define any if compiling for the Wiring platform
// Interrupt handlers for Arduino
#if defined(_useTimer1)
SIGNAL (TIMER1_COMPA_vect)
handle_interrupts(_timer1, &TCNT1, &OCR1A);
#endif
#if defined(_useTimer3)
SIGNAL (TIMER3_COMPA_vect)
handle_interrupts(_timer3, &TCNT3, &OCR3A);
#endif
#if defined(_useTimer4)
SIGNAL (TIMER4_COMPA_vect)
handle_interrupts(_timer4, &TCNT4, &OCR4A);
#endif
#if defined(_useTimer5)
SIGNAL (TIMER5_COMPA_vect)
handle_interrupts(_timer5, &TCNT5, &OCR5A);
#endif
#elif defined WIRING
// Interrupt handlers for Wiring
void Timer1Service()
#endif
void Timer3Service()
#endif
#endif
static void initISR(timer16_Sequence_t timer)
#if defined (_useTimer1)
if(timer == _timer1) {
TCCR1A = 0; // normal counting mode
TCCR1B = _BV(CS11); // set prescaler of 8
TCNT1 = 0; // clear the timer count
#if defined(__AVR_ATmega8__)|| defined(__AVR_ATmega128__)
TIFR |= _BV(OCF1A); // clear any pending interrupts
TIMSK |= _BV(OCIE1A) ; // enable the output compare interrupt
#else
// here if not ATmega8 or ATmega128
TIFR1 |= _BV(OCF1A); // clear any pending interrupts
TIMSK1 |= _BV(OCIE1A) ; // enable the output compare interrupt
#endif
#if defined(WIRING)
timerAttach(TIMER1OUTCOMPAREA_INT, Timer1Service);
#endif
#endif
#if defined (_useTimer3)
if(timer == _timer3) {
TCCR3A = 0; // normal counting mode
TCCR3B = _BV(CS31); // set prescaler of 8
TCNT3 = 0; // clear the timer count
#if defined(__AVR_ATmega128__)
TIFR |= _BV(OCF3A); // clear any pending interrupts
ETIMSK |= _BV(OCIE3A); // enable the output compare interrupt
#else
TIFR3 = _BV(OCF3A); // clear any pending interrupts
TIMSK3 = _BV(OCIE3A) ; // enable the output compare interrupt
#endif
#if defined(WIRING)
timerAttach(TIMER3OUTCOMPAREA_INT, Timer3Service); // for Wiring platform only
#endif
#endif
#if defined (_useTimer4)
if(timer == _timer4) {
TCCR4A = 0; // normal counting mode
TCCR4B = _BV(CS41); // set prescaler of 8
TCNT4 = 0; // clear the timer count
TIFR4 = _BV(OCF4A); // clear any pending interrupts
TIMSK4 = _BV(OCIE4A) ; // enable the output compare interrupt
#endif
#if defined (_useTimer5)
if(timer == _timer5) {
TCCR5A = 0; // normal counting mode
TCCR5B = _BV(CS51); // set prescaler of 8
TCNT5 = 0; // clear the timer count
TIFR5 = _BV(OCF5A); // clear any pending interrupts
TIMSK5 = _BV(OCIE5A) ; // enable the output compare interrupt
#endif
static void finISR(timer16_Sequence_t timer)
//disable use of the given timer
#if defined WIRING // Wiring
#if defined(__AVR_ATmega1281__)||defined(__AVR_ATmega2561__)
TIMSK1 &= ~_BV(OCIE1A) ; // disable timer 1 output compare interrupt
#else
TIMSK &= ~_BV(OCIE1A) ; // disable timer 1 output compare interrupt
#endif
timerDetach(TIMER1OUTCOMPAREA_INT);
else if(timer == _timer3) {
TIMSK3 &= ~_BV(OCIE3A); // disable the timer3 output compare A interrupt
#else
ETIMSK &= ~_BV(OCIE3A); // disable the timer3 output compare A interrupt
#endif
timerDetach(TIMER3OUTCOMPAREA_INT);
#else
//For Arduino - in future: call here to a currently undefined function to reset the timer
(void) timer; // squash "unused parameter 'timer' [-Wunused-parameter]" warning
#endif
static boolean isTimerActive(timer16_Sequence_t timer)
// returns true if any servo is active on this timer
for(uint8_t channel=0; channel < SERVOS_PER_TIMER; channel++) {
if(SERVO(timer,channel).Pin.isActive == true)
return true;
return false;
/****************** end of static functions ******************************/
Servo::Servo()
if( ServoCount < MAX_SERVOS) {
this->servoIndex = ServoCount++; // assign a servo index to this instance
servos[this->servoIndex].ticks = usToTicks(DEFAULT_PULSE_WIDTH); // store default values - 12 Aug 2009
this->servoIndex = INVALID_SERVO ; // too many servos
uint8_t Servo::attach(int pin)
return this->attach(pin, MIN_PULSE_WIDTH, MAX_PULSE_WIDTH);
uint8_t Servo::attach(int pin, int min, int max)
if(this->servoIndex < MAX_SERVOS ) {
pinMode( pin, OUTPUT) ; // set servo pin to output
servos[this->servoIndex].Pin.nbr = pin;
// todo min/max check: abs(min - MIN_PULSE_WIDTH) /4 < 128
this->min = (MIN_PULSE_WIDTH - min)/4; //resolution of min/max is 4 us
this->max = (MAX_PULSE_WIDTH - max)/4;
// initialize the timer if it has not already been initialized
timer16_Sequence_t timer = SERVO_INDEX_TO_TIMER(servoIndex);
if(isTimerActive(timer) == false)
initISR(timer);
servos[this->servoIndex].Pin.isActive = true; // this must be set after the check for isTimerActive
return this->servoIndex ;
void Servo::detach()
servos[this->servoIndex].Pin.isActive = false;
if(isTimerActive(timer) == false) {
finISR(timer);
void Servo::write(int value)
if(value < MIN_PULSE_WIDTH)
{ // treat values less than 544 as angles in degrees (valid values in microseconds are handled as microseconds)
if(value < 0) value = 0;
if(value > 180) value = 180;
value = map(value, 0, 180, SERVO_MIN(), SERVO_MAX());
this->writeMicroseconds(value);
void Servo::writeMicroseconds(int value)
// calculate and store the values for the given channel
byte channel = this->servoIndex;
if( (channel < MAX_SERVOS) ) // ensure channel is valid
if( value < SERVO_MIN() ) // ensure pulse width is valid
value = SERVO_MIN();
else if( value > SERVO_MAX() )
value = SERVO_MAX();
value = value - TRIM_DURATION;
value = usToTicks(value); // convert to ticks after compensating for interrupt overhead - 12 Aug 2009
uint8_t oldSREG = SREG;
cli();
servos[channel].ticks = value;
SREG = oldSREG;
int Servo::read() // return the value as degrees
return map( this->readMicroseconds()+1, SERVO_MIN(), SERVO_MAX(), 0, 180);
int Servo::readMicroseconds()
unsigned int pulsewidth;
if( this->servoIndex != INVALID_SERVO )
pulsewidth = ticksToUs(servos[this->servoIndex].ticks) + TRIM_DURATION ; // 12 aug 2009
pulsewidth = 0;
return pulsewidth;
bool Servo::attached()
return servos[this->servoIndex].Pin.isActive ;
#endif // ARDUINO_ARCH_AVR
After experimenting with those and other methods, I discovered that pins 5,6 work well even when the Servo is defined and connected, which is exactly how I intended pins 44,45 to behave. I would prefer to work on 44,45 for this program due to mechanical considerations, and other pins on the board, including 5,6, will be in use; if there is anyone who could help me with that issue, it would be really appreciated.
