I'm having issues getting timer code to work. At this point the timed operation (solenoid valve) never turns on. My project is a self flushing litter box because let's face it, who likes to dump it. The algorithm is simple: x times per day, solenoid water valve on for y seconds. If float sensor = water, pump on fox z seconds. If float sensor = water> 60 seconds, shutdown and alarm.
#define VALVE 2
#define PUMP 3
#define SENSOR 4
#define ALARM 13
long cleaning_number = 6; // How many operations should be executed for day
long interval = long((1000L*60L*60L*24L)/cleaning_number); // Interval between cleanings in milliseconds
int valve_time=20; // Time of opening valve in seconds
int pump_time= 25; // Time of working pump in seconds
int counter=0;
long counter2=0;
pinMode(VALVE, OUTPUT);
pinMode(PUMP, OUTPUT);
pinMode(ALARM, OUTPUT);
pinMode(SENSOR, INPUT_PULLUP);
digitalWrite(VALVE, HIGH);
digitalWrite(PUMP, HIGH);
digitalWrite(ALARM, LOW);
Serial.println("Start programming");
Serial.print("Interval: ");
Serial.println(interval);
if(counter2*5000 > interval){
counter2=0;
digitalWrite(VALVE, LOW);
delay(valve_time*1000);
Serial.println("Valve activation");
if(digitalRead(SENSOR)){
digitalWrite(PUMP, LOW);
while(digitalRead(SENSOR)){
counter++;
if(counter>pump_time*2){
while(true){
digitalWrite(ALARM, HIGH);
delay(300);
delay(300);
counter=0;
delay(5000);
counter2++;
