timer keep going under sleep mode ?
Hi, All
Currently I am working at the timer of a project. The goal is to set the LCD into sleep_mode_pwr_down from a certain set time and then countdown. It will display the remain time for a few seconds once push the button ( an interrupt ). So my question is how to keep the timer running while in sleep mode ? Any one can give me some hints or a link of similar project ?
From the code I have by now, it stops to countdown once the sleep mode starts.
Please give me as much suggestions as possible. Many thanks in advance.
Best~,
I think the "IDLE" mode is the shallowest sleep of all and it will keep the timers running.
Peter_n: I think the "IDLE" mode is the shallowest sleep of all and it will keep the timers running.
Thank you for your reply, Peter_n. However, the "IDLE" mode only has the least power savings. Any suggestions under the " POWER_DOWN" or " POWER_SAVE" mode ?
No, but the WatchDog has also a timer, you can keep that running and power everything else down. It is very (very) inaccurate, so an RTC is needed to know the time.
