I'm trying to implement my own (finer-grained) PWM
here's the code so far:
//timerTest
int counter = 0;
int pwm = 0;
int pwmMax = 20;
#define LEDPIN 10
boolean once = false;
//set pin as output
pinMode(LEDPIN, OUTPUT);
void mySetup(void)
// stop interrupts
cli();
//set timer2 interrupts
TCCR2A = 0;
TCCR2B = 0;
TCNT2 = 0;
// set compare match register
// for number of increments
OCR2A = 1; // changing this seems to have no effect
// turn on CTC mode
TCCR2A |= _BV(WGM21);
// Set prescaler
TCCR2B |= _BV(CS20);
// enable timer compare interrupt
TIMSK2 |= (1 << OCIE2A);
//allow interrupts
sei();
ISR(TIMER2_COMPA_vect)
counter++;
if (counter > pwmMax)
counter = 0;
if (counter < pwm && pwm > 0)
digitalWrite(LEDPIN, HIGH);
if (counter >= pwm)
digitalWrite(LEDPIN, LOW);
int i;
if (!once)
mySetup();
once = true;
for (i=0; i<pwmMax; i++)
pwm++;
delay(2000);
pwm--;
delay(2000);
it almost works in that it does spit out a PWM signal on the required pin
but ...
a) it seems to effect how delay(2000) works - far less than two seconds
b) altering the line with OCR2A= seems to make no difference
what I want to achieve is
a) prescaler of 1
b) PWM frequency > 1 kHz
c) range of 0 - 1023 or better still 0-2048
what did I miss?
cheers
Mike
