Timer not working as expected?
hello, when i make a sketch, i found on some code surround, the timer not working as expected: only execute one time, it should not happen but it does. i checked for many time but can't figure out why this happen. thank you for any suggestion.
here are my codes, i deleted the code does not relation. copy the all codes below, serial monitor, the problem will reproduce.
#include "arduino-timer.h"
auto timer = timer_create_default();
boolean verify_passed = false;
boolean led_receiving_data = false;
  timer.every(2000, toggle_led);
  timer.tick();
  if (verify_passed == false) {
    led_receiving_data = true;
void toggle_led() {
  Serial.print("a");    //<----------- only execute one time
  if (led_receiving_data == true) {
    Serial.print("b");
If I remember correctly the callback needs to return a boolean and if it's true then the timer will repeat
try with
bool toggle_led() {
  Serial.print("a");
  return true;
@weigangjiang, your topic was moved to a more suitable location on the forum.
There's no led_receiving_data = false;
i use your suggestion and problem fixed, thank you very much.
by the way, below code is work and without return true;
  timer.tick();
void toggle_led() {
  Serial.print("a");
anyway, thank you again.
You might be lucky :wink:
