Hello everyone,,
I am working on a IR transmitter that requires a 40KHZ modulated frequency. I am using timer1 to generate the 40KHZ and turning it on and off via timer 2. The output of timer 1 ( pin 10 on my Nano) is connected to the LED. The problem that I am having is that when I turn off timer 1, the output needs to be LOW, so the LED goes off. I'm finding that it can be randomly HIGH or LOW. Is there a way to force the output low after I disable the timer?
I have tried using digitalWrite and directly writing to the parallel port registers. I can't seem to use the timer output once I have done that.
Any ideas?
Thanks,
Afjhal.
