LeeEng
February 16, 2016, 11:53am
1
I'm trying to run a simple timer but it doesnt seem to want to work. Its going to go in a much bigger project but want to get it working before i port it over to the project.
unsigned long time;
unsigned long TIMEA = 12000;
unsigned long TIMEB = 0;
int button = 0;
int buttonc = 0;
int Timer = 0;
void setup(){
pinMode(A5, INPUT_PULLUP); //Button
pinMode(9, OUTPUT);
void loop(){
button = digitalRead(A5);
if (button == LOW) {
if (buttonc == 0){
buttonc = 1;
Timer = 1;
Serial.print("Time Start: ");
time = millis();
//prints time since program started
Serial.println(time);
TIMEB = time + TIMEA;
Serial.print("Time Off: ");
Serial.println(TIMEB);
digitalWrite(9, HIGH);}
else {
buttonc = 0;
if (Timer == 1){
if (TIMEB == time){
Serial.print("Time Stop: ");
digitalWrite(9, LOW);
Timer = 0;
The last part is the part i cannot get to work. (if (TIMEB == time) onwards)
Anyone that can help me would be good.
system
February 16, 2016, 11:56am
3
Have you tried ">=" instead?
LeeEng
February 16, 2016, 12:04pm
4
I have tried both >= and >.
Nothing happens the LED i have connected to pin 9 stays on.
if i make it <= it turns the LED off stright away
You have serial output. Can you please post a dump of that?
LeeEng
February 16, 2016, 12:24pm
6
aarg:
Serial output would be
Time Start: 5201
Time Off: 17201
then i get nothing out after that
if i press the button again after the 12 seconds i would get
Time Start: 21582
Time Off: 33582
as for me
main error is (TIMEB == time), where time is not refreshed with millis() value.
also :
trigger on push button is not accurate => may execute several time start (one for each two loop)
use millis() absolute value leads to roll over pb. correct use is (millis() - start > duration)
system
February 16, 2016, 12:29pm
8
When you can get the code you posted to compile, get back to us.
Because neither of these two variables are changed or updated in loop, once the timer sequence starts.
if (TIMEB == time)
Your formatting is garbage. Here, I had to fix it just so I could stand to read it:
unsigned long time;
int button = 0;
int buttonc = 0;
int Timer = 0;
pinMode(9, OUTPUT);
if (button == LOW)
if (buttonc == 0)
buttonc = 1;
Timer = 1;
time = millis();
buttonc = 0;
if (Timer == 1)
if (TIMEB == time)
Timer = 0;
LeeEng
February 16, 2016, 12:38pm
11
bricoleau:
Now i get where the problem is Thank
After if (Timer ... i need to refresh time.
bricoleau:
i am using this part of the code to stop the loop
if (buttonc == 0){
buttonc = 1;
Why so complicated?
unsigned long intervalStart;
const unsigned int duration = 12000;
bool idle = true;
pinMode(9, OUTPUT);
if (idle) {
if (!digitalRead(A5)) {
intervalStart = millis();
Serial.println(intervalStart);
Serial.println(intervalStart + duration);
idle = false;
} else if (millis() - intervalStart >= duration) {
Serial.println(millis());
idle = true;
LeeEng
February 16, 2016, 12:44pm
13
just tested it and work fine amended code here
unsigned long time;
int button = 0;
int buttonc = 0;
int Timer = 0;
pinMode(9, OUTPUT);
if (button == LOW)
if (buttonc == 0)
buttonc = 1;
Timer = 1;
time = millis();
buttonc = 0;
if (Timer == 1)
time = millis();
if (TIMEB == time)
Timer = 0;
system
February 16, 2016, 12:57pm
14
I would certainly change this if (TIMEB >= time)
Replace (button == LOW) by (button == LOW && Timer == 0)
And then, buttonc is useless
I hope your program won't need to run for more than 49 days (millis() roll over)
For example :
loop() duration = 10 ms with other stuff
TimeB set to 2^32 - 5 after something like 49 days running
stop condition like (TimeB <= millis()) may be never achieved
Right code should be something like :
static bool idle = true;
static unsigned long start;
const unsigned long duration = <whatever>;
if (idle)
if (<start condition>)
start = millis();
idle = false;
else if (millis() - start >= duration)
idle = true;
bricoleau:
That is the framework of the working version I already posted in #11
system
February 16, 2016, 1:53pm
20
bricoleau:
For example :
I'm not sure I'm following your argument here.
