Timer Question
Hi guys.
I have a question for a timer. Essentially, when the switch is operated, the buzzer needs to come on for 500ms and then go off. I could use a delay but I really don’t want to for obvious reasons. I am not familiar with any other timer method so could somebody please shed some light :slight_smile:
If someone could please also explain to me how a message can be shown on an LCD but only whilst the state for it to be on is high, and then the message to dissapear when it is low I would be very thankful! I am aware of the clear function but I do not want to clear the whole screen. The part of code I am talking about for the LCD is at the message “RIDE STOPPED”.
Here is the part of the code I am talking about and the buzzer is “buzzerPin”. It is currently implementing a delay for a timer.
 pressurePlateState = digitalRead(pressurePlate);
   if(pressurePlateState != lastPressurePlateState){
    if(pressurePlateState == LOW){
      digitalWrite(ledGreenPin, HIGH);
      digitalWrite(ledRedPin, LOW);
      digitalWrite(buzzerPin, HIGH);
      delay(200);
      digitalWrite(buzzerPin, LOW);
    }else{
      digitalWrite(ledRedPin, HIGH);
      digitalWrite(ledGreenPin, LOW);
    lastPressurePlateState = pressurePlateState;
And here is the full code (unfinished)
#include <LiquidCrystal.h>
const int reedPin = 10;
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
const int safetySwitch = 9;
const int ledRedPin = 14;
const int ledGreenPin = 15;
const int ledPin = 8;
const int buzzerPin = 16;
const int pressurePlate = 18;
int reedState = 0;
int lastReedState = 0;
int reedCounter = 0;
int minuteCounter = 0;
int safetySwitchState = 0;
int lastSafetySwitchState = 0;
int pressurePlateState = 0;
int lastPressurePlateState = 0;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
  pinMode(reedPin, INPUT);
  pinMode(safetySwitch, INPUT);
  pinMode(ledRedPin, OUTPUT);
  pinMode(ledGreenPin, OUTPUT);
  pinMode(buzzerPin, OUTPUT);
  lcd.begin(16, 2);
  lcd.setCursor(0,0);
  lcd.print("Minute wait:");
  lcd.setCursor(12,0);
  lcd.print(minuteCounter);
  lcd.setCursor(2,1);
  lcd.print("RIDE OPEN");
reedState = digitalRead(reedPin);
 if(reedState != lastReedState) {
  if(reedState == LOW){
   reedCounter++;
   if(reedCounter % 6 == 0) {
    minuteCounter++;
   lastReedState = reedState;
 safetySwitchState = digitalRead(safetySwitch);
 if(safetySwitchState != lastSafetySwitchState){
  if(safetySwitchState == HIGH){
    lcd.setCursor(2,1);
    lcd.print("RIDE STOPPED");
    }else{
      lcd.setCursor(2,1);
      lcd.print("RIDE OPEN   ");
  delay(100);
  lastSafetySwitchState = safetySwitchState;
      delay(200);
    }else{
Thanks very much in advance.
Marcus
Do you have a grasp on the first five demos in IDE->file/examples/digital ? Take a look too at 'Demonstration code for doing several things at the same time'.
Marcusarduino:
Once you understand state change detection you can do this easily. It also means you can print to the LCD when some boolean state *goes * high/low and erase when it goes low/high.
To print:
   lcd.setCursor(2,1);
To clear:
   lcd.setCursor(2,1);
    lcd.print("            "); // 12 spaces
@OP
To use TC1 of the MCU for generating 'time delay', you may consult this post and also this post.
