Timer question
Simple Question Like most I'm new, but learning fast, and have a question.
How do I start the program over in 7 days?
Delay wont work, the program is doing all kinds of stuff, I think I need a timer or clock function but everything I have seen deals with building clocks or LCD clocks I don't need that complicated.
Tnx
Delay wont work,
Why not? 7UL * 24UL * 60UL * 60UL * 1000UL
...that you haven't shown us. (hint)
Hit the reset button after 7 days. Maybe connect a servo to do it for you.
Seriously, what exactly needs to restart after 7 days? There should be no reason to restart the Arduino after 7 days. Making the code repeat some action(s) every 7 days is understandable, and there is even a TimedAction library that makes this easy.
//Ok for the code here goes
I’m really just trying to combine 2 pieces of code together
1st one is a bunch of relays that will go off once, and then again “every 7 days”.
The second is a PH sensor that should be on, all the time, except when the relays go off.
I’m lost how to do this it shouldn’t be that hard.
//The 1st one… relays
pinMode(13, OUTPUT); //drain
pinMode(12, OUTPUT); //solinoid
pinMode(11, OUTPUT); //A nutrient solution
pinMode(10, OUTPUT); //B nutrient solution
pinMode(9, OUTPUT); //PH down
digitalWrite(13, HIGH); // set the drain on
delay (1000UL * 10UL * 60UL); //10 min delay
digitalWrite(13, LOW); // set the drain off
digitalWrite(9, HIGH); //set the PH down on
delay (30000); //30 second delay
digitalWrite(9, LOW); //sets the PH down off
digitalWrite(11,HIGH); //sets nutrient A on
digitalWrite(10, HIGH); //sets nudtent B on
delay (1000ul * 1UL * 60UL); //1 min delay
digitalWrite(11, LOW); //sets nutrient A off
digitalWrite(10, LOW); //sets nutrient B off
digitalWrite(12,HIGH); //sets the solinoid on
digitalWrite(12, LOW); //sets solinoid off
delay (7UL * 24UL * 60UL * 60UL * 1000UL); //7 day delay
///The second one… PH
#include <NewSoftSerial.h>
NewSoftSerial mySerial = NewSoftSerial(2, 3);
char stamp_data[15];
byte holding;
byte i;
byte startup=0;
void setup(){
mySerial.begin(38400);
if(startup==0){
for(i=1; i <= 2;i++){
mySerial.print(“l0”);
mySerial.print(13,BYTE);
mySerial.print(“l1”);
startup=1;
mySerial.print(“c”);
if(mySerial.available() > 3) {
holding=mySerial.available();
for(i=1; i <= holding;i++){
stamp_data*= mySerial.read();*
  • for(i=1; i <= holding;i++){*
    Serial.print(stamp_data*);
    _
    }_
    _
    Serial.println("");_
    _
    }_
    _
    }*_
The delay() function really should be renamed to twiddleYourThumbsAndDoNothingElseForAWhile() to get the point across that nothing else happens while delay() is going on. If you delay(oneWeek), you won’t be reading the PH sensor during that thumb twiddling time.
On the other hand, if, on every pass through loop, you see if enough time has elapsed to warrant reading the pH sensor, and if so, read it, then see it enough time has elapsed to warrant running the pumps for a while, and if so, do it, you CAN do both at the same time.
The millis() function will tell you how long the Arduino has been running. If you track when the pumps were last run, you can determine if it is time to do it again. Like this:
unsigned long lastPumpTime = 0;
unsigned long pumpInterval = 7UL * 24UL * 60UL * 60UL * 1000UL;
   unsigned long now = millis();
   if(now - lastPumpTime > pumpInterval)
      // run the pumps
      lastPumpTime = now;
   // Same concept for PH sensor
"millis() function" I was thinking Id need an actual clock code since I couldn’t figure this out. Going to read all I can on the millis() function, and try it out. Thanks your wonderful Id buy you a beer anytime.
OK tried writing the code, used only one millis function, as I want everything to to loop in 7 days.
Sketch doesn’t like it, it gives me an error at the bottom }
tnx
byte holding;
byte i;
byte startup=0;
void setup(){
digitalWrite(10, HIGH); //sets nutrient B on
delay (1UL * 24UL * 60UL * 60UL * 1000UL);
if(startup==0){
startup=1;
    _
    }_
    _
    _
    lastPumpTime = now;_
    _
    } *_
You're first IF statement needs brackets enclosing the commands you want to run once every week.
well I don't see a 7 day delay, a one day delay but I have that one because I don't want any readings for a day after all the nutrient changes gives it time to stabilize. The bracket thing I'm lost can you give me a hint?.
How much of the following code do you want executed when this is true? If just the next line, no { or } are needed. If you want more than one statement executed, all the statements to be executes need to be enclosed in { and }.
well Id like the whole thing to start over
added some brackets no luck
code
byte holding;
byte i;
byte startup=0;
void setup(){
{ //added these no luck
delay (1UL * 24UL * 60UL * 60UL * 1000UL); // one day delay, to stabilize before reading PH
if(startup==0){
startup=1;
    _
    }_
    _
    _
    _
    } *_
Here’s my take on a scheduler that will do roughly what you want. It’s designed to be expandable.
All the intervals are currently constants but variables and other unsigned long integer expressions will work as well.
//  Some macros for defining time intervals in milliseconds
#define seconds_in_ms(s) ((s)*1000UL)
#define minutes_in_ms(m) ((m)*60UL*1000UL)
#define hours_in_ms(h)   ((h)*60UL*60UL*1000UL)
#define days_in_ms(d)    ((d)*24UL*60UL*60UL*1000UL)
#define weeks_in_ms(w)   ((w)*7UL*24UL*60UL*60UL*1000UL)
unsigned long CycleStartTime = 0;
unsigned long LastTaskTime = 0;
unsigned long CurrentTaskInterval = 0;
unsigned Task = 0;
  unsigned long currentTime = millis();
  // If the time has not yet come to perform a task
  if (currentTime - LastTaskTime < CurrentTaskInterval)
    return;   // Nothing to do
  LastTaskTime = currentTime;
  switch (Task++)
  case 0:
    CycleStartTime = currentTime;  // Remember this time
    CurrentTaskInterval = minutes_in_ms(10);
  case 1:
    digitalWrite(9, HIGH);  // set the PH down on
    CurrentTaskInterval = seconds_in_ms(30);
  case 2:
    CurrentTaskInterval = minutes_in_ms(1);
  case 3:
  case 4:
    CurrentTaskInterval = days_in_ms(1);
  case 5:
    //  Put some stuff here to do 1 day after the solenoid turns off
    // Start over again in one week from the START of the cycle
    Task = 0;
    LastTaskTime = CycleStartTime;
    CurrentTaskInterval = weeks_in_ms(1);
Wow tnx but I Tried this no go
byte holding;
byte i;
byte startup=0;
#define seconds_in_ms(s) ((s)1000UL)
#define minutes_in_ms(m) ((m)60UL1000UL)
#define hours_in_ms(h) ((h)60UL60UL
1000UL)
#define days_in_ms(d) ((d)24UL60UL60UL1000UL)
#define weeks_in_ms(w) ((w)7UL24UL60UL60UL1000UL)
unsigned Task = 0;
switch (Task++)
case 0:
case 1:
case 2:
case 3:
case 4:
case 5:
if(startup==0){
startup=1;
stamp_data
= mySerial.read();*
    _
    }_
    _
    _
    }_
    _
    }_
    _
    Task = 0;_
    _
    LastTaskTime = CycleStartTime;_
    _
    break;_
    _
    }_
    _
    }*_
The code you added was badly formed and had an extra close-bracket at the end.
When you take code that compiles, and add stuff, and it then DOESN’T compile: you probably added an error. :\
Try adding this stuff in place of the stuff you added:
    if(startup == 0)
        mySerial.print("l0");
        mySerial.print("l1");
      startup=1;
      mySerial.print("c");
        stamp_data[i]= mySerial.read();
        Serial.print(stamp_data[i]);
      Serial.println("");
I owe you a beer
it works
tnx
code
EDIT: Moderator code put in code box. OP, please go back over previous posts, click “modify”, highlight your code, then click on the # icon on the toolbar, then click “save”. AWOL
byte holding;
byte i;
byte startup=0;
unsigned Task = 0;
  switch (Task++)
  case 0:
  case 1:
  case 2:
  case 3:
  case 4:
  case 5:
if(startup == 0)
      startup=1;
      Serial.println("");
    Task = 0;
