Timer question
I want to be able to call a function during the "setup" part of my program for about 3 seconds. I want to pass a value from an EEPROM address to this function. Then continue with setup.
I then want to call this same function during loop but let it do its job with out the value from the EEPROM.
Does this sound feasible?
I have just been thinking about this and it won’t work. I will need to create a second function as the first one won’t use the EEPROM value as I want, it will overwrite it with its own values.
Another question.
Do I put the timer in the setup area then call a function I want to run for 3S then return Or do I call the function and have the 3 second timer in the function.
windoze_killa:
I want to be able to call a function during the “setup” part of my program for about 3 seconds. I want to pass a value from an EEPROM address to this function. Then continue with setup.
I’m not sure what you mean by “I want to be able to call a function during the “setup” part of my program for about 3 seconds”. In terms of calling the function with or without an EEPROM address you can do one of two things:
  1. Declare the function with a default argument:
void foo(int address=0)
    // do something
  1. Overload the function:
void foo(int address)
    // do something
void foo()
    // do something else
windoze_killa:
Yes, it is possible. You just need to use a global variable or static variable to store the value from EEPROM in the first call (from setup() function ).
For example
void foo(int address = 0)
  static bool isReadFromEEPROM = false;
  static int valueReadFromEEPROM;
  if (isReadFromEEPROM == false)
    valueReadFromEEPROM = ;// read from eeprom code
    isReadFromEEPROM = true;
Thanks. I will have a play when I get home tonight.
As I expected it didn't work. The function gets data from another variable when running so it ignores the EEPROM data. I will just right a second function that doesn't and call that one during setup.
