Timer routine help
2560 Mega connected to a motor controller, brushed motor, 16x2 LCD.
I've got a menu built with a settings option where you can select Increase Time or Decrease Time. Time defaults to 1 minute. Once the time is set I want to be able to go to another menu and start the motor routine that will run for that specified amount of time.
I start off with a global variable: int time_minutes = 1;
when the user selects that from the menu it runs the following:
void menu_increaseTime() { lcd.clear(); lcd.setCursor(0,0); time_minutes = time_minutes + 1; lcd.print(time_minutes); lcd.print(" minutes"); }
void menu_decreaseTime() { lcd.clear(); lcd.setCursor(0,0); if (time_minutes > 0) time_minutes = time_minutes - 1; lcd.print(time_minutes); lcd.print(" minutes");
the first time I select it displays 10 minutes, then 20 minutes, the 29, 39, 48, 57, 65, etc. decrease shows 56, 48, 39, 30, 22, 14, 7, then 0
It should be increasing or decreasing the amount of time by increments of 1. Any ideas?
Second I need to be able to run my motor controller routine for the amount of time specified in the time_minutes variable. Any suggestions for a routine to do that?
Are you debouncing your buttons?
This is a bare-bones solution. Nothing fancy.
digitalWrite(motorpin, HIGH);
delay(time_minutes*60000);
digitalWrite(motorpin, LOW);
What does debouncing the buttons mean? I’m using a 16x2 LCD with built in buttons. They output an analog signal on a single analog input and then based on the value returned a subroutine determines the button selected. It’s not perfect but seems to work ok.
Any idea why the value of the time_minutes variable doesn’t increase by 1 each time I run it?
Any idea why the value of the time_minutes variable doesn't increase by 1 each time I run it?
Yes
http://lmgtfy.com/?q=arduino+debounce
Could be an artifact of the LCD display. Use Serial.print() to print a message each time the switch is pressed, and to output the time_minutes value. See if they match, or not, in the Serial Monitor.
