Timer.setinterval
Hi there
I am new at Arduino and at this forum.
I do not understand completely the Arduino sketch philosophy.
Assume I would need to call 3 functions to run my code, my question is how many Timer.setInterval
functions should I use in void setup()?
Thank for some help.
Thank you Delta_G
What really happens is that I am learning about using Arduino with Blynk apps.
They put something like this in the setup() function:
// Debug console
Serial1.begin(56700);
delay(5000); // Allow board to settle
Blynk.begin(auth);
// Setup a function to be called every second
timer.setInterval(1000L, sendAmp);
timer.setInterval(1000L, SEmail);
//Blynk.email("Email address ", "High Amps limit reached", "Amps >7.0");
Blynk.run();
timer.run();
The function definition for sendAmp() and SEmail() are located before void setup()
But what stuck me is I am setting timer.setInterval with two subsequent arguments.
It seem to me that is not correct.
Thank you very much for your help.
The setInterval (or something like it) is only needed for functions that should be run at specific intervals.
loop runs much faster and can call any functions like @Delta_G showed you.
BTW sending EMails each second seems a rather strange idea to me (and probably your provider).
You don't have to use setInterval if you manage the timing yourself.
const unsigned long emailAll = 1000;
const unsigned long ampAll = 1000;
const unsigned long someFuncAll = 60000UL;
unsigned long lastEmail;
unsigned long lastAmp;
unsigned long lastSomeFunc;
  Serial1.begin(250000);
  Blynk.begin(auth);
  unsigned long topLoop = millis();
  Blynk.run();
  if (topLoop - lastAmp >= ampAll) {
    lastAmp = topLoop;
    sendAmp();
  if (topLoop - lastEmail >= emailAll) {
    lastAmp = topLoop;
    SEmail();
  if (topLoop - lastSomeFunc >= someFuncAll) {
    lastSomeFunc = topLoop;
    someFunc();
Hi Whandall
Thank you very much for tour clear explanation.
I understood your code and .....where are initialized these variables before void setup() ?:
As global variables they are initialized to zero.
Thank you very much Whandall I forgot that!!!!
