使用timer.setinterval出現無法轉換的問題
想要使用blynk接收訊息,但是在使用timer.setInterval(1000L, Show_Acc);會出現以下error:invalid conversion from ‘void ()(int)’ to 'timer_callback {aka void ()()}’ [-fpermissive],請幫我看一下哪裡出了問題,謝謝。
void setup(){
Wire.begin();
Serial.begin(115200); // start serial for output. Make sure you set your Serial Monitor to the same!
Serial.println("\nSetup, init");
Blynk.begin(auth, ssid, pass);
I2C_Bus_Check();
YAL210_Initial(YAL210_I2C_Addr);
Serial.println("\nStart loop");
//==============================Arduino loop function==============================//
void loop(){
Show_Acc(YAL210_I2C_Addr);
delay(100);
Blynk.run();
timer.run();
void Show_Acc(int YAL210_I2C_Addr){
float X_CNT=0, Y_CNT=0, Z_CNT=0, X_G=0, Y_G=0, Z_G=0;
YAL210_acc_t rawAccel = YAL210_acc.readRawAccel(YAL210_I2C_Addr);
#ifdef calibration
// Display the results (acceleration is measured in m/s^2)
X_CNT = rawAccel.XAxis - AccOffset.XAxis;
Y_CNT = rawAccel.YAxis - AccOffset.YAxis;
Z_CNT = rawAccel.ZAxis - AccOffset.ZAxis;
#else
X_CNT = rawAccel.XAxis;
Y_CNT = rawAccel.YAxis;
Z_CNT = rawAccel.ZAxis;
#endif
X_G = ((X_CNT / (pow(2,Resolution) / (Range * 2))) * 9.81);
Y_G = ((Y_CNT / (pow(2,Resolution) / (Range * 2))) * 9.81);
Z_G = ((Z_CNT / (pow(2,Resolution) / (Range * 2))) * 9.81);
Blynk.virtualWrite(V1, X_CNT);
Blynk.virtualWrite(V2, Y_CNT);
Blynk.virtualWrite(V3, Z_CNT);
Blynk.virtualWrite(V4, X_G);
Blynk.virtualWrite(V5, Y_G);
Blynk.virtualWrite(V6, Z_G);
delay(10);
Serial.print(“X Axis: “); Serial.print(X_CNT);Serial.print(” counts ( “);
Serial.print(X_G); Serial.print(” m/s^2 )”); Serial.print("\t\t");
Serial.print(“Y Axis: “); Serial.print(Y_CNT);Serial.print(” counts ( “);
Serial.print(Y_G); Serial.print(” m/s^2 )”); Serial.print("\t\t");
Serial.print(“Z Axis: “); Serial.print(Z_CNT);Serial.print(” counts ( “);
Serial.print(Z_G); Serial.print(” m/s^2 )”); Serial.print("\t\t");
