system
February 3, 2014, 6:24pm
1
Hello,
just have a question. I didnt find an answer in other threads about sleep mode
I want to let start ardunio executing a sketch after i pressed a button. So after uploading arduino uno should go to sleep modus.
I write it in the following way.
void sleep() //
Serial .println("going to sleep");
delay(50);
set_sleep_mode (SLEEP_MODE_PWR_DOWN);
sleep_enable();
attachInterrupt (1, wake, HIGH);
sleep_disable();
detachInterrupt(1);
[/quote]
and
void wake () //
sleep_disable();
detachInterrupt(1);
Serial .println("waking up");
[/quote]
it works, but arduino needs some time to leave the sleep modus.
But i have a function in my sketch. I use a timer for it.
Timer1.initialize(8000000); //
Timer1.attachInterrupt(function); //
void function()
so if try to use these lines of code in my sketch, the sketch doesnt start.
I saw here Arduino Playground - HomePage written that its not alowed to use the timer in the function
void wake () //
[/quote] and i dont use a timer in this function., but thesketch doesnt work.
system
February 3, 2014, 7:08pm
2
I'm sure that the fine folks at http://snippets-r-us.com will be happy to look at your snippets.
system
February 3, 2014, 7:35pm
3
Here is the sketch. If I use a timer, the sketch does not start(does nothing)
#include <avr/sleep.h>
#include <TimerOne.h>
#include <LiquidCrystal_I2C.h> //
#include <Sensirion.h> //
#include <Wire.h>
#include <DS1307RTC.h>
#include <Time.h>
#include <SD.h>
const int PWM_pin = 5;
const int Lightsensor = 2;
const int switch = 3;
const uint8_t dataPin = 6; //
const uint8_t clockPin = 7; //
const int chipSelect = 10;
static boolean Start = true;
byte pwm=200;
float Temperature=0; //
float Humidity=0;
float Taupunkt=0;
volatile unsigned long x = 0; //
unsigned long previousMillis = 0;
volatile unsigned long y = 0;
Sensirion Temperatursensor = Sensirion(dataPin, clockPin);
LiquidCrystal_I2C lcd(0x20,16,2);
void setup(){
lcd.init();
lcd.backlight();
pinMode(PWM_pin, OUTPUT);
pinMode(Lightsensor, INPUT); //
pinMode(switch,INPUT);
attachInterrupt(0, count, RISING);
//attachInterrupt(1, wake, HIGH);
Timer1.attachInterrupt(mesure); //
void mesure()
void wake () //
sleep_disable();
detachInterrupt(1);
Serial.println("waking up");
void loop (){
if (digitalRead(switch)==HIGH) { //
if (Start){ //
y=0;
Serial.println("Start Motor."); //
analogWrite(PWM_pin,pwm);
previousMillis = millis(); //
x = 0; //
Start = false;
if (millis()-previousMillis>1000){ //
previousMillis = millis(); // Startzeit setzen
Serial.print("RPM= ");Serial.print(x*60);Serial.println("RPM"); //
if ( x*60<2520)
{ analogWrite(5,pwm++);}
if ( x*60>2550)
{ analogWrite(5, pwm--);}
if ( x*60==0)
{ analogWrite( 5, 0);}
y+=x;
x = 0; //
}else { //
Start = true;
sleep();
} // end loop()
void count(){
x++;
void sleep() //
Serial.println("going to sleep");
delay(50);
sleep_enable();
sleep_disable();
detachInterrupt(1);
system
February 4, 2014, 12:02am
4
Does anybody has an idia?
system
February 4, 2014, 8:49am
5
Can anybody say please, how can I avoid using a Timer if want some function works for example every 10 seconds?
Your program already has an example of how to do it
system
February 4, 2014, 9:38am
7
UKHeliBob:
But I cannot use this lines outside of loop ()? I mean in setup ()
system
February 4, 2014, 9:39am
8
OK. I'll bite. Why can't you?
system
February 4, 2014, 10:01am
9
Motorcontrol.ino: In function 'void setup()':
Motorcontrol:52: error: a function-definition is not allowed here before '{' token
Motorcontrol:191: error: expected `}' at end of input
#include <Wire.h>
#include <Time.h>
#include <SD.h>
const int switchpin = 3;
byte pwm=200;
float Humidity=0;
float Taupunkt=0;
void setup(){
lcd.init();
lcd.backlight();
pinMode(switchpin,INPUT);
if (millis()-previousMillis>8000){ //
mesure();
void mesure()
Serial.begin (9600);
Temperatursensor.measure(&Temperature, &Humidity, &Taupunkt); //
Serial.print (x);
lcd.print(x);
File mesureFile = SD.open("mesured.txt", FILE_WRITE); //
if (mesureFile)
//Schreibe auf SD-Karte
mesureFile.print("Temperature: ");
mesureFile.print(Temperature); //
mesureFile.println("°C");
mesureFile.print("Humidity: ");
mesureFile.print(Humidity);
mesureFile.println("%");
mesureFile.println ("cycles");
mesureFile.print (x);
mesureFile.print(day());
mesureFile.print(":");
mesureFile.print(month());
mesureFile.print(year());
mesureFile.print("; ");
mesureFile.print(hour());
mesureFile.print(minute());
mesureFile.print(second());
mesureFile.println("; ");
mesureFile.close();
Serial.println("Erroo");
digitalWrite(A0, HIGH);
void wake () //
sleep_disable();
detachInterrupt(1);
void loop (){
if (Start){ //
y=0;
x = 0; //
Start = false;
if ( x*60<2520)
if ( x*60>2550)
if ( x*60==0)
y+=x;
x = 0; //
}else { //
Start = true;
sleep();
} // end loop()
void count(){
x++;
void sleep() //
delay(50);
sleep_enable();
sleep_disable();
detachInterrupt(1);
The error has nothing to do with the use of miilis() for timing.
Try Auto Format on you code for a clue as to the problem. It will probably be more obvious what the problem is if you put each opening and closing brace on its own line.
system
February 4, 2014, 10:37am
11
Can you tell me please what can be the problem if i use Timer. initialize from the first sketch (third post)?
Let's establish a baseline. Does this slightly modified example from the Timer1 library work ?
pinMode(13, OUTPUT);
Timer1.attachInterrupt( timerIsr ); // attach the service routine here
void timerIsr()
// Toggle LED
digitalWrite( 13, digitalRead( 13 ) ^ 1 );
If so, then you know that the Timer1 library is working and we can go on from there.
system
February 4, 2014, 11:28am
13
Yes, the sketch works.
The question of the thread was, why does timer1 not work with the sleep mode? Are there some especialnesses?
