Timer, USART, ADC, etc. Interrupts
Hello!
I have seen people used timer ISRs, USART0 ISRs, ADC ISRs. There are probably more types of ISRs. I only know how to use pin change interrupts. I found some code like this:
#define ledPin 13
  pinMode(ledPin, OUTPUT);
  // initialize timer1
  noInterrupts();           // disable all interrupts
  TCCR1A = 0;
  TCCR1B = 0;
  TCNT1  = 0;
  OCR1A = 31250;            // compare match register 16MHz/256/2Hz
  TCCR1B |= (1 << WGM12);   // CTC mode
  TCCR1B |= (1 << CS12);    // 256 prescaler
  TIMSK1 |= (1 << OCIE1A);  // enable timer compare interrupt
  interrupts();             // enable all interrupts
ISR(TIMER1_COMPA_vect)          // timer compare interrupt service routine
  digitalWrite(ledPin, digitalRead(ledPin) ^ 1);   // toggle LED pin
  // your program here...
All the manipulating of the constants are very confusing. How can I change that code to make the ISR trip at different intervals (100ms, 1000ms, 50ms, etc.)? What's the prescaler, and all that? Most of these ISRs use a syntax like this:
ISR(USART0_TX_vect){ /*Some code*/ }
ISR(ADC_vect){ /*Some code*/}
Can someone show me good guides to all kinds of interrupts, or teach me how to use these kinds of interrupts?
Thanks!
EDIT: Meant to add, see section 12 in the datasheet for the interrupt vectors.
For the moment I'm trying to work with USART0_RX_vect but I'm in trouble with compilation.
Have you take a look on AVR-GCC interrupt library ?
http://www.nongnu.org/avr-libc/user-manual/group__avr__interrupts.html
May be it can help you
TCCR1A = 0;
TCCR1B = 0;
TCNT1 = 0;
I'm just learning how to do all this myself. Those callouts are for the registers in
the ATmega328. It will help to download the datasheet for the chip, and cross-
reference the code with the actual register info, then it's very easy to figure out
how to modify the register values.
Code such as TCCR1B |= (1 << WGM12); is simply shifting a "1" into the proper
bitwise position, and then setting the bit in the register.
Another thing that will help is to get a copy of Dale Wheat's book "Arduino
Internals", as he spends a lot of time describing examples of how to do Timer
register settings and interrupts.
