Timer Used
Hey guys,
I have a question. I want to mix normal avr-gcc code with arduino. I am using the timer one 16 bit in CTC Mode on Pin 26 on the atmega1280.
Which timer is used by delay() or millis() and can I still use them when using the settings mentioned above?
Greetz, Mic
The 8-bit Timer0 is used on the Duemilanove for millis() and delay(). I didn't see any special code for the mega so it should be the same for both.
Korman
Thank you! I will try playing with my arduino. Hope it works!
