Timer with offset
Hello,
I need to program a timer for three relays(controlled by mosfets).
The problem is that I want an offset between triggering the relays, but have the same off and on time for the three timers.
I am stuck, cannot think of an efficient way of doing this, but I am sure some of you know the answer :slight_smile:
What do you mean by an offset considering that the relays have the same off and on time ?
Do you perhaps mean that they have the same off and on periods ?
Does a single event trigger the start of the sequence ?
UKHeliBob:
The relays has the same off and on time, but I need them to turn on and off with an offset to each other
Like this:
Relay 1:on-off-off-off-on-off-off-off
Relay 2:off-on-off-off-off-on-off-off
Relay 3:off-off-on-off-off-off-on-off
Does that make any sense? As said, the on and off time is the same for all
It sounds like you need some code that changes state at regular intervals (the duration of one of the periods in your diagram) and at each interval a relay gets turned on or off. Perhaps have a counter that starts at 1 and counts up at each interval and goes back to 1 after 3. If the count is 1, then turn relay 1 on. If the count is 2 turn relay 2 on etc.
I suspect this is not exactly what you need, but it should put you on the write right track.
...R
Edited to correct an appalling error - using write when I intended right - apologies to everyone
Robin2:
I suspect this is not exactly what you need, but it should put you on the write track.
...R
Thank you, that was not a bad idea :slight_smile:
I was going to try and describe this but it was easier to write a program
//Relay 1:on-off-off-off-on-off-off-off
//Relay 2:off-on-off-off-off-on-off-off
//Relay 3:off-off-on-off-off-off-on-off
const byte states[]  {
  0b10001000,
  0b01000100,
  0b00100010
const byte relayPins[] = {10, 11, 12};
int bitIndex;
  for (int pin = 0; pin < 3; pin++)
    pinMode(relayPins[pin], OUTPUT);
  bitIndex = bitIndex - 1;
  if (bitIndex < 0)
    bitIndex = 7;
  for (int relay = 0; relay < 3; relay++)
    digitalWrite(relayPins[relay], bitRead(states[relay], bitIndex));
NOTE : I used delay() as an illustration. You may need to use millis() for timing if other things need to happen in loop()
UKHeliBob:
const byte states  {
  0b10001000,
  0b01000100,
  0b00100010
const byte relayPins = {10, 11, 12};
int bitIndex;
  if (bitIndex < 0)
    bitIndex = 7;
Thank you, I will tinker a bit with this when I have the time :slight_smile: Great to get new insight on how codes can be used.
