hi..I'm trying to build a digital timer with preset times using a 7-segment display with 4 digits(catalex display with TM1637 ), a rotary encoder and Arduino nano, so you can select a time and start a countown, after which an LED lights for 10 seconds but it doesnìt seem to work ... i am attaching the code
#include "TM1637.h"
#define CLK_PIN (4)
#define DIO_PIN (3)
#define NUM_DIGITS (4)
TM1637 tm1637( CLK_PIN, DIO_PIN, NUM_DIGITS );
int index;
volatile int direction;
int InterruptPin = 2;
int RotaryEncoder2 = 7;
int PushButton = 8;
int AlarmPin = 9;
int SignalozPin = 10;
Serial.println("OnFire's Timer");
uint8_t digits[] = {0, 0, 0, 0};
char *str = " ";
tm1637.setDigits( str );
tm1637.setDot( 1, false );
tm1637.update();
// imposta i pin
pinMode(InterruptPin, INPUT);
pinMode(RotaryEncoder2, INPUT);
pinMode(PushButton, INPUT);
pinMode(AlarmPin, OUTPUT);
pinMode(SignalozPin, OUTPUT);
uint16_t count = 0;
void Direction()
// Questa funzione viene attivata da un interrupt dal coso rotativo sul pin "Interrupt Pin"
// verificare interrupt, ora controllare l'altro pin dal coso rotativo per stabilire la direzione
if (digitalRead(RotaryEncoder2))direction = +1;
else direction = -1;
return;
void Alarm(int Signal)
int temp = 500;
if (Signal == 1) // tono itermittente
{ while (1)
{ tone(AlarmPin, 1000, 500);
if (digitalRead(PushButton) == HIGH)break;
noTone(AlarmPin);
if (Signal == 2)
{ while (1)
{ tone(AlarmPin, 900);
delay(temp = (750 - temp));
// noTone(AlarmPin);
tone(AlarmPin, 1250);
noTone(AlarmPin);
return;
// tempi predefiniti
int Times[] = {0, 2, 10, 20, 21, 30, 40, 50, 60, 72, // up to 1m
75, 90, 105, 120, 144, 150, 180, 210, 240, 270, 300, // up to 5m
330, 360, 390, 420, 432, 450, 480, 510, 540, 570, 600, // up to 10m
660, 720, 780, 840, 900, 960, 1020, 1080, 1140, 1200, // up to 20m
1320, 1440, 1560, 1680, 1800, 2100, 2400, 2700, 3000, 3300, 3600, // up to 1h
3900, 4200, 4500, 4800, 5100, 5400
int nTimes, StartCounting = 0, Time, Count, CountDown, Reset;
long Delta;
nTimes = sizeof(Times) / sizeof(Times[0]) - 1;
Serial.print("tempi: ");
Serial.println(nTimes);
// inizia a 00:00
index = 0;
Time = Times[index];
StartCounting = 0;
CountDown = 0;
// // la direzione non è definita
direction = 0;
// Attendere linput e la visualizzazione dei secondi richiesti
while (1)
// Aggiungere +1 o -1 per prevenire ln ritardo dl cambiamento di rotazione
if (direction != 0)
{ index = index + direction;
// Verificare di non andare al di la di limiti di matrice -oveflow-
if (index < 0)index = nTimes;
if (index > nTimes)index = 0;
// mostra il nuovo tempo
StartCounting = 0;
// Resetta, altrimenti aumenta o diminuisce in continuazione
direction = 0;
// mostra il tempo corrente
WriteTime(Time);
// verifica lo stato HIGH sul pin 8 - ( pulsantozzo per avviare, mettere in pausa e resettare il timer)
// Una breve pressione corrisponde a START / pausa, una pressione più lunga, azzera
// il pulsante è stato premuto ora aspetta fino a quando viene rilasciato
Count = 0; // Numero di intervalli di 10ms che si preme il pulsantozzo
Reset = 0; // reset o start / mette in pausa
while (digitalRead(PushButton) == HIGH)
{ delay(10);
Count++;
// Lasciare 500ms (10ms x 50) il tasto premuto per abilitare il tasto di reset
if (Count > 50)
{ index = 0;
Time = 0;
StartCounting = 0; // stoppato
WriteTime(Time); // Scrivere il tempo in modo che il display si azzera a 0:00 mentre si preme il pulsante
CountDown = 0; // Conteggio fermo
Reset = 1; // Così possiamo saltare il prossimo blocco di codice.......#peoplefrompigrizia
while (digitalRead(PushButton) == HIGH); //ripete in loop finché il pulsante viene rilasciato
} // END OF WHILE(DIGITALREAD(8))
// Basta una rapida pressione per iniziare o mettere in pausa
if (Reset == 0)
{ StartCounting = 1 - StartCounting;
if (index == 0)CountDown = +1;
else CountDown = -1;
Delta = millis() / 1000;
// Avvia il conteggio ... CountDown dà la direzione
if (StartCounting == 1)
{ if (millis() / 1000 != Delta)
{ Time = Time + CountDown;
if (Time == 0)
{ CountDown = 0;
WriteTime(Time);
index = 0;
Alarm(2);
// quando finisce il countdown, da 5v al pin 10
if (Time == 0)
SignalozPin == HIGH;
delay (10000);
} // END OF IF(STARTCOUNTING...
} // END OF WHILE(1)
} // END OF loop()
// con molta calma
// WriteTime () il formato di visualizzazione è MM : SS
void WriteTime(int time)
{ int second, minute;
int d0, d1, d3, d4;
int digit[11] = {63, // 0
6, // 1
91, // 2
79, // 3
102,// 4
109,// 5
125,// 6
7, // 7
127,// 8
111,// 9
0
}; // space
second = time % 60;
minute = time / 60;
// Impostare dx al valore di ogni cifra
d0 = 10;
if (minute >= 10)d0 = minute / 10;
d1 = minute % 10;
d3 = second / 10;
d4 = second % 10;
tm1637.setDigits( time );
tm1637.setDigits(1);
return;
where am I wrong ?? thank you ![]()
