Timer
have anyone tried to use more than one mode of timer (overflow, CTC,etc) at the same time ? :slight_smile:
i'm using timer1 in arduino uno.
:slight_smile:
Since each timer only has one WGM (Waveform Generator Mode) field, how would you propose setting it to more than one mode at the same time?
ok, it make sense. :slight_smile:
so, can we use timer1 and timer2 together at same time ?
Yes, for the same reason that you can use arduino 1 and arduino 2 at the same time.
wendo:
Depends on what you mean by "together". You can certainly use them at the same time.
