Timer
Is there a way to create a timer without using any pin or Arduino?
http://en.wikipedia.org/wiki/555_timer_IC
i was not thinking at that timer
i have a timer function
      TCCR2A &= ~((1<<WGM21) | (1<<WGM20));
      TCCR2B &= ~(1<<WGM22);
      TCCR2B = (1<<CS22)|(1<<CS21);
      ASSR |=(0<<AS2);
      // Use normal mode
      TCCR2A =0;
      //Timer2 Overflow Interrupt Enable
      TIMSK2 |= (0<<OCIE2A);
      TCNT2=0x06;  // counting starts from 6;
      TIMSK2 = (1<<TOIE2);
      SREG|=1<<SREG_I;
// Timer2 interrupt routine - 1/(160000000/256/(256-6)) = 4ms interval
ISR(TIMER2_OVF_vect)
      TCNT2  = 6;
      UpdateKey();
that i use to update a keypad buttons status
The problem is that i need to use pwm on pin 3 to control my lcd back light,but because of this timer i can’t(the light is off)
so i need something like a new thread to update the buttons staus and use pin 3 as pwm
what i have to change to use timer 1 instead of timer 2 in that function because 0n pins 9 and 10 i use digitalWrite, so they are not affected by the timer?
Do you really need to programmaticly change the backlight intensity? Why not just connect a potentiometer between +V, ground, and the backlight, and twist a knob?
I don't need to programmatically change the back light intensity, i ca use a pot, but this is a good opportunity for me to learn how to use timers
You can avoid hw timers altogether and use the millis() function, like this:
int t;
  t = millis();
  if (millis() - t > 1000) {
    t = millis();
    // do action
action gets executed every 1000ms.
