timer1 code help
Hello!
I found a useful tutorial about using timers on arduino, and I tried to hack an example to make some tests.
This sketch, should work this way:
1- receive an external signal and trigger an external interrupt
2- the external interrupt function (tachSignal) sets timer1 to wait for a certain amount of time
3- when the ISR runs, it turns on an led and then sets timer1 for another time interval
4- when the ISR runs again, it turns off the led and reset timer1
here is the sketch:
// Arduino timer CTC interrupt example
// www.engblaze.com
// avr-libc library includes
#include <avr/io.h>
#include <avr/interrupt.h>
#define LEDPIN 2
int delayTicks = 100;
int outputTicks = 30;
int interruptIter = 0;
attachInterrupt(0,tachSignal,FALLING);
  pinMode(LEDPIN, OUTPUT);
     // initialize Timer1
    cli();          // disable global interrupts
    TCCR1A = 0;     // set entire TCCR1A register to 0
    TCCR1B = 0;     // same for TCCR1B
    // enable global interrupts:
    sei();
void tachSignal(){
  // set compare match register to desired timer count:
    OCR1A = delayTicks;
// turn on CTC mode:
    TCCR1B |= (1 << WGM12);
// Set CS10 and CS12 bits for 1024 prescaler:
    TCCR1B |= (1 << CS10);
    TCCR1B |= (1 << CS12);
// enable timer compare interrupt:
    TIMSK1 |= (1 << OCIE1A);
    sei();
interruptIter = 0;
ISR(TIMER1_COMPA_vect)
if(interruptIter == 0){
  digitalWrite(LEDPIN, HIGH);
    OCR1A = outputTicks;
    sei();
interruptIter = 1;}else{
  digitalWrite(LEDPIN, LOW);
  sei();}
I’m not sure if this code is correct, I’m not sure about disabling interrupts within the interrupt routine.
Any advice is greatly appreciated!
Variables used in an interrupt service routine have to be declared volatile.
monsterfactory: Hello! I found a useful tutorial about using timers on arduino, and I tried to hack an example to make some tests. This sketch, should work this way: 1- receive an external signal and trigger an external interrupt 2- the external interrupt function (tachSignal) sets timer1 to wait for a certain amount of time 3- when the ISR runs, it turns on an led and then sets timer1 for another time interval 4- when the ISR runs again, it turns off the led and reset timer1
here is the sketch:
So have you tried to run the code? How does it work? What errors do you see?
