Hello again,
I have a slight problem with Timer1 in arduino while coding it in assembly. I try to run the Timer1 in CTC mode - I configure everything well in my opinion, but the TCNT1 just doesn't increment each clock, as it should. I checked the registers in Atmel Studio and everything seems okay, but maybe I forgot about something?
Here is the code
.ORG 0
jmp start
.ORG 0x22
call isr_toggle_PA0
.ORG 0x400
start:
LDI R16, HIGH(RAMEND)
OUT SPH, R16
LDI R16, LOW(RAMEND)
OUT SPL, R16 ; initialize stack pointer
clr r16
ldi r16, 0xff
out DDRA, r16 ; port A output
ldi r16, 0x00
out DDRD, r16 ; port D input
clr r16
ldi r20, 1<<OCIE1A
sts TIMSK1, r20 ; enable Timer1 A comapre match interrupt
sei
ldi r20, HIGH(25000)
sts OCR1AH, r20
ldi r20, LOW(25000)
sts OCR1AL, r20
ldi r20, 0b00000010 ; CTC mode, int clk;
sts TCCR1A, r20
ldi r20, 0b000000101 ; prescaler /1024
sts TCCR1B, r20
ldi r20, 0
sts TCCR1C, r20
; --- start main
main:
inc r16
rjmp main
; --- end main
isr_toggle_PA0: // toggle bit on PA0
ldi r16,0x00000001
in r17, PORTA
eor r17,r16
out PORTA, r17
reti
Thank you for your help ![]()
Best regards
