Timer1 not firing
I am trying to set up Timer1 in CTC with a rate of 500Hz:
 //  controlling pins A=pin9. B=pin10
 pinMode(10, OUTPUT);
 pinMode(9, OUTPUT); //
  TCCR1A &= (unsigned char)~0b11110011; // zeros are reserved bits
//  TCCR1A |= 0b00;  // WGM1[1,0] = 0b00, with WGM1[3,2]=01 for CTC; WGM1[3]=0 i/p
  TCCR1A |= 0b11100000;  // COM1A[1,0]= TCCR1A[7.6]=10; COM1B[1,0]= TCCR1A[5,4]=10 ; clear on match
                         // COM1A[1,0]= 1 ; inv-output  // normal DIO
//  TCCR1B[7,6] : input capture only, noise filter , edge detection. [5] reserved
//                NB only on 16b counter cf force comp on 8b
  TCCR1B &= ~0b11111;
  TCCR1B |=  0b01101; // 01101: WGM2[3,2]=01 + "div 1024" -> 16kHz tick: OCR1A sets count ...
  OCR1A = 16; // set cycle length = 16kHz /16/2 = circa 1/2 kHz
     338:       80 e1           ldi     r24, 0x10       ; 16
     33a:       90 e0           ldi     r25, 0x00       ; 0
     33c:       90 93 89 00     sts     0x0089, r25
     340:       80 93 88 00     sts     0x0088, r24
  TIMSK1 = 0b001; // in CTC, TOV1 triggers at MAX, ie OCR1A match
now with the exception of the possible unsafe write , this compiles as I expected.
However, when I run it the inverted op stays high and the other low. No PWM.
I had no trouble setting up Timer2 so there must be something I'm over looking or something in the library code that is messing this up that I am not aware of.
Can anyone see what's wrong?
thx
You just need to set COM1A0 and COM1B0 (TCCR1A register) to toggle on compare match, instead of 'set on compare match' :
 pinMode(9, OUTPUT);
  TCCR1A |= 0b01010000;  // COM1A[1,0]= TCCR1A[7.6]=10; COM1B[1,0]= TCCR1A[5,4]=10 ; clear on match
  TCCR1B &= ~0b11111;
or how I find it easiest:
  pinMode(9,OUTPUT);
  pinMode(10,OUTPUT);
  TCCR1A = _BV(COM1A0) | _BV(COM1B0);
  TCCR1B = _BV(WGM12) | _BV(CS12) | _BV(CS10);
  OCR1A = 16;
  TIMSK1 = _BV(TOIE1);
Of course, I was mixing up the timings with the phase corrected modes. Clearly I need to toggle in CTC.
I actually find these mnemonics are just as cryptic as plain binary: remembering what WMG12 means is the same as remembering what TCCR1B[5] does except that I need to learn two names instead of one. (Not Arduinos fault, that's the Atmel doc) but it's as cryptic a binary at the end of the day.
I either need to define some const values that are human readable (which is probably what Arduino should have done) or liberally spray my code with comments. Until I find out exactly how all this hangs together , it's the latter.
 pinMode(9, OUTPUT);
  TCCR1A |= 0b01000000;  // COM1A[1,0]= TCCR1A[7.6]=01; COM1B[1,0]= TCCR1A[5,4]=00 ; normal DIO
                         // COM1A[1,0]= 01 ; toggle output to chk freq on pin 9 //
  TCCR1B &= ~0b11011111; // [7,6] noise canceller=0; [5] resv.
  TIMSK1 = 0b001; // in CTC, TOIE1 bit: TOV1 triggers at MAX, ie OCR1A match
That seems to be the same as what you posted.
My TIMER1_OVF_vect() is getting called now as I intended. And I get 500Hz on pin 9
Thanks for your help in seeing this silly error.
Of course the other error was that in CTC the timer counter never overflows so setting up TIMER_OVF_vect is a waste of time.
TIMSK1 = 0b010;
TIMER1_COMPA_vect()
That finally does what I intended
Thanks again.
