I have the following code running on an Arduino Nano:
volatile int x = 1000;
bool y = 0;
volatile long a = 0;
long b = 0;
TCCR2A |= 0;
TCCR2B |= 0x04; //prescaler set to 1/64
OCR2A |= 0xFF; //this can be adjusted later
TIMSK2 |= 0b10; //set interrupts
Serial.println(TCCR2B,BIN);
if(y == 1){
Serial.println(a-b);
b = micros();
y=0;
SIGNAL(TIMER2_COMPA_vect){
if(x==0){
a = micros();
y = 1;
x = 1000;
x--;
I would expect that with a 16mhz system clock and a divider of 64 that the interrupt should trigger roughly once every millisecond and decrementing a counter down from 1000 should give me an output every second. What I'm getting though is over 2 seconds.
2039644
2039644
2039652
2039652
2039652
2039652
2039644
2039644
2039652
2039652
2039652
2039644
2039644
2039652
Thoughts?
