TimerONE and NRF24L01p.h doesnt work
Hi all,
I am a newbie for programming.
My program have a TimerONE and NRF24L01p.h library. This library is ok. There is no problem but IF i will use RF, my program cant go loop and cant complete setup section… And totaly FAILS…
But i need both on my program. Because i measure testing time for my products and logging.
Otherwise ; i dont setup my RF, TimerONE starting to work. Or i dont setup TimerONE, RF starting work.
What can i do ?
Thank you for responses.
These are sample codes.
// Setup section start
Timer1.initialize(1000); // 1 mikro saniye hassasiyet
Timer1.attachInterrupt(callback); // callback() çıkışı al
Serial.begin(19200); // Open serial port with 9600bps
RF.channel(90);
RF.RXaddress(“Hasbi”);
RF.init();
// Setup section end
// Startup configration
#include <SPI.h>
#include <nRF24L01p.h>
nRF24L01p RF(7,8);
#include “TimerOne.h”
What RF24 library are you using? I don't recognize "nrf24L01p.h
Why do you need to use the Timer library?
This Simple nRF24L01+ Tutorial may help.
Also, please always post a complete program. And please post your code between [code] [/code] tags so your code looks like thisand is easy to copy to a text editor.
...R
Robin2:
What RF24 library are you using? I don’t recognize "nrf24L01p.h
Also, please always post a complete program. And please post your code between tags so
…R
Thanks for response…
My codes here ; cant enter loop and arduino nano fail…
#include <SPI.h> // SPI kütüphanesi
#include <nRF24L01p.h>  // RF kütüphanesi
nRF24L01p alici(7,8);  // RF tanımlama
#include "TimerOne.h"  // TimerOne kütüphanesi
uint16_t microseconds = 0, milliseconds = 0, test = 1;
uint8_t seconds = 0, minutes = 0, hours = 0;
String ekran = "";
void callback()
 if(test == 1){
   milliseconds += 1;
   if (milliseconds == 1000)
     milliseconds = 0;
     seconds++;
   if (seconds == 60)
     seconds = 0;
     minutes++;
   if (minutes == 60)
     minutes = 0;
     hours++;
void reset()
  microseconds = 0, milliseconds = 0;
  delay(250);
  delay(250);
  Serial.println("00:00:000");
  delay(250);
  alici.channel(90);
  alici.RXaddress("Hasbi");
  alici.init();
  // Gelmiş verileri resetle başlangıç
  char char_readed = 0;
  alinan="";
  Serial.println(alinan);
  // Gelmiş verileri resetle bitiş
  // Gelen verileri derleme başlangıç (RS232 ve RF sinyalleri)
  char_readed = Serial.read();  // Read serial port character
  if(alici.available()>0){
    alici.read();
    alici.rxPL(alinan);
    if(alinan!=""){
      // Boş gelmediği sürece devam edecek
Fixed ! Thank you.
I have forget to add codes below;
SPI.begin();
SPI.setBitOrder(MSBFIRST);
Don't forget it yours :slight_smile:
SPI clock = 4 MHz, bit order = MSBFIRST, and SPI Mode 0 are the defaults, you don't need to set them after SPI.begin().
