TimerOne and Serial Library
I’m working using TimerOne library, the code is shown below:
#include <TimerOne.h>
pinMode(13, OUTPUT);
Timer1.initialize(1000000); // set a timer of length 1000000 microseconds
Timer1.attachInterrupt(timerIsr); // attach the service routine here
Serial.println(millis());
void timerIsr() {
Serial.print("FROM Time1: ");
The problem is, after some loops (when millis of loop() returns 930), the arduino stop
I think that the problem is, when the arduino is running the loop, and write in Serial port, the ISR Routine is writing too. How can I solve this problem?
I try change:
by:
digitalWrite(13, !digitalRead(13));
And work fine, I think that the Serial library of arduino has some problem when use interrupts, It’s possible?
There’s one way to block arduino in some block, I try use atomic and didn’t work.
I’m using arduino UNO (ATmega328)
It's possible?
It's entirely possible; you should never use Serial in an interrupted context.
But when I remove:
Serial.println(millis()); from loop
Work well in ISR Routine, I think that the problem is: when ISR Routine try use Serial at the same time of loop()
I think you should never use Serial in an ISR.
YMMV.
I spent a lot of time to discovery.
Just one
Serial.flush();
:confused:
Thanks :smiley:
I don't understand your reply.
Nothing, only the solution, for others
Ah! Playing with us, you are. “Serial.flush” a double-edged light sabre, it is.
FWIW, there is no (one) solution.
I chose my words carefully. I didn’t say “One should never use Serial in an ISR”, and I didn’t say “I never use Serial in an ISR”.
I liked of yoda voice
kkkkkkkkkkkkkkkk XD
