TimerOne.h Arduino Due
hello,
i run a project code and i need TimerOne.h library but its not support by due… any help for that?
// Testing sketch for 50Hz !!!
#include <TimerOne.h>
unsigned char channel_1 = 7; // Output to Opto Triac pin, channel 1
unsigned char channel_2 = 6; // Output to Opto Triac pin, channel 2
unsigned char channel_3 = 5; // Output to Opto Triac pin, channel 3
unsigned char channel_4 = 4; // Output to Opto Triac pin, channel 4
unsigned char CH1, CH2, CH3, CH4;
unsigned char i=0;
unsigned char delay_time=25; // delay ms or flashing SPEED
unsigned char clock_tick; // variable for Timer1
unsigned char CHANNEL_SELECT; // variable for channel select
unsigned char CH[]={CH1,CH2,CH3,CH4};
unsigned char dim_level[]={5,8,10,12,15,18,20,25,30,35,45,50,55,60,65,70,75,80,82,85,88,92,95}; // don't use this massive for 60Hz
 // create new massive for 60Hz
 pinMode(channel_1, OUTPUT);// Set AC Load pin as output
 pinMode(channel_2, OUTPUT);// Set AC Load pin as output
 pinMode(channel_3, OUTPUT);// Set AC Load pin as output
 pinMode(channel_4, OUTPUT);// Set AC Load pin as output
 attachInterrupt(1, zero_crosss_int, RISING);
 Timer1.initialize(100); // set a timer of length 100 microseconds for 50Hz or 83 microseconds for 60Hz;
 Timer1.attachInterrupt( timerIsr ); // attach the service routine here
void timerIsr()
 clock_tick++;
 if (CH[0]==clock_tick)
 digitalWrite(channel_1, HIGH); // triac firing
 delayMicroseconds(10); // triac On propogation delay (for 60Hz use 8.33)
 digitalWrite(channel_1, LOW); // triac Off
 if (CH[1]==clock_tick)
 digitalWrite(channel_2, HIGH); // triac firing
 digitalWrite(channel_2, LOW); // triac Off
 if (CH[2]==clock_tick)
 digitalWrite(channel_3, HIGH); // triac firing
 digitalWrite(channel_3, LOW); // triac Off
 if (CH[3]==clock_tick)
 digitalWrite(channel_4, HIGH); // triac firing
 digitalWrite(channel_4, LOW); // triac Off
void zero_crosss_int() // function to be fired at the zero crossing to dim the light
 // Every zerocrossing interrupt: For 50Hz (1/2 Cycle) => 10ms ; For 60Hz (1/2 Cycle) => 8.33ms
 // 10ms=10000us , 8.33ms=8330us
 clock_tick=0;
for (CHANNEL_SELECT=0;CHANNEL_SELECT<4;CHANNEL_SELECT++) // fade up
 for (i=22;i>1;i--)
 CH[CHANNEL_SELECT]=dim_level[i];
 delay(delay_time);
delay(2000);
for (CHANNEL_SELECT=0;CHANNEL_SELECT<4;CHANNEL_SELECT++) // fade down
 for (i=0;i<22;i++)
 delay(delay_time);
Hi there @hackertom,
Have a look to tc_lib, library available at: GitHub - antodom/tc_lib: This is a library to take advantage of different functionalities available on Timer Counter (TC) modules in Arduino Due's Atmel ATSAM3X8E microcontrollers
The DUE has a different microcontroller, an Atmel ATSAM3X8E, it does not have the same timers you can find in Arduino UNO's ATmega328P.
Have a look to the examples thata comes with tc_lib, specifically to example action_test.ino which uses action objects. I think that's what you want.
If you have any doubt, just ask me.
I hope it helps.
Try DueTimer
#include <DueTimer.h>
void setup(){
Timer3.attachInterrupt(timerIsr).setFrequency(50).start(); //outputs regulator controler at 50 Hz
BTW, when posting code, use code tag formatin.
Regards.
Nitrof
If anyone's willing to merge this timer code into TimerOne, please submit a pull request on github.
