Hello, I'm running the adafruit Metro M4 SamD51 board. I'm trying to run a menu for a oled screen with an encoder. I'm having a problem when I try to run the code I get this error
WARNING: library TimerOne-master claims to run on avr architecture(s) and may be incompatible with your current board which runs on samd architecture(s).
C:\Users\JjC\AppData\Local\Temp\arduino_modified_sketch_283783\1.54oled_text_animation.ino: In function 'void setup()':
1.54oled_text_animation:48:10: error: 'class TimerOne' has no member named 'initialize'
48 | Timer1.initialize(1000);
Take a search engine of your choice and ask the WWW for 'Metro M4 SamD51 +timerone' to collect some data to be sorted out to get the needed information.
I have been looking. I see a lot of people talking about this. Mostly are saying becuase of the newer IDE. The timer one is from an older ide and I can’t find a newer update version for it.
"TimerOne" is referring to Timer / Counter 1 on an AVR processor (as evidenced by the error message you got). It makes no sense to talk about a "TimerOne Library" for a non-AVR processor. The SAMD51 processor has a other peripheral resources that can be used for this purpose. You'll need to search for a solution based on the hardware you're using.
