TimerOne library question
Hi, I want to ask the difference of the functions of start()&attachinterrupt and stop()&detachinterrupt
and I saw the example when initialize() give the period of interrupt ,attachinterrupt() only need to give one argument of the interrupt function,but I read the C file it needs two arguments: the interrupt function and the period of interrupt. I dont understand the detail of the assembly language,so can any one could explain it ??
Thanks a lot.
The start method starts (or restarts) the timer running. The attachInterrupt() method defines what to do when the timer ticks.
The stop() method stops the timer. The detachInterrupt() method causes the defined function to stop being called when the timer ticks.
You’ll need to provide more details. What C file are you reading? Have you looked at the corresponding header file? There might be a default argument defined.
header
#ifndef TIMERONE_h
#define TIMERONE_h
#include <avr/io.h>
#include <avr/interrupt.h>
#define RESOLUTION 65536    // Timer1 is 16 bit
class TimerOne
  public:
    // properties
    unsigned int pwmPeriod;
    unsigned char clockSelectBits;
	char oldSREG;					// To hold Status Register while ints disabled
    // methods
    void initialize(long microseconds=1000000);
    void start();
    void stop();
    void restart();
	void resume();
	unsigned long read();
    void pwm(char pin, int duty, long microseconds=-1);
    void disablePwm(char pin);
    void attachInterrupt(void (*isr)(), long microseconds=-1);
    void detachInterrupt();
    void setPeriod(long microseconds);
    void setPwmDuty(char pin, int duty);
    void (*isrCallback)();
extern TimerOne Timer1;
#endif
CPP file
#ifndef TIMERONE_cpp
#define TIMERONE_cpp
#include "TimerOne.h"
TimerOne Timer1;              // preinstatiate
ISR(TIMER1_OVF_vect)          // interrupt service routine that wraps a user defined function supplied by attachInterrupt
  Timer1.isrCallback();
void TimerOne::initialize(long microseconds)
  TCCR1A = 0;                 // clear control register A
  TCCR1B = _BV(WGM13);        // set mode 8: phase and frequency correct pwm, stop the timer
  setPeriod(microseconds);
void TimerOne::setPeriod(long microseconds)		// AR modified for atomic access
  long cycles = (F_CPU / 2000000) * microseconds;                                // the counter runs backwards after TOP, interrupt is at BOTTOM so divide microseconds by 2
  if(cycles < RESOLUTION)              clockSelectBits = _BV(CS10);              // no prescale, full xtal
  else if((cycles >>= 3) < RESOLUTION) clockSelectBits = _BV(CS11);              // prescale by /8
  else if((cycles >>= 3) < RESOLUTION) clockSelectBits = _BV(CS11) | _BV(CS10);  // prescale by /64
  else if((cycles >>= 2) < RESOLUTION) clockSelectBits = _BV(CS12);              // prescale by /256
  else if((cycles >>= 2) < RESOLUTION) clockSelectBits = _BV(CS12) | _BV(CS10);  // prescale by /1024
  else        cycles = RESOLUTION - 1, clockSelectBits = _BV(CS12) | _BV(CS10);  // request was out of bounds, set as maximum
  oldSREG = SREG;
  cli();							// Disable interrupts for 16 bit register access
  ICR1 = pwmPeriod = cycles;                                          // ICR1 is TOP in p & f correct pwm mode
  SREG = oldSREG;
  TCCR1B &= ~(_BV(CS10) | _BV(CS11) | _BV(CS12));
  TCCR1B |= clockSelectBits;                                          // reset clock select register, and starts the clock
void TimerOne::setPwmDuty(char pin, int duty)
  unsigned long dutyCycle = pwmPeriod;
  dutyCycle *= duty;
  dutyCycle >>= 10;
  oldSREG = SREG;
  cli();
  if(pin == 1 || pin == 9)       OCR1A = dutyCycle;
  else if(pin == 2 || pin == 10) OCR1B = dutyCycle;
  SREG = oldSREG;
void TimerOne::pwm(char pin, int duty, long microseconds)  // expects duty cycle to be 10 bit (1024)
  if(microseconds > 0) setPeriod(microseconds);
  if(pin == 1 || pin == 9) {
    DDRB |= _BV(PORTB1);                                   // sets data direction register for pwm output pin
    TCCR1A |= _BV(COM1A1);                                 // activates the output pin
  else if(pin == 2 || pin == 10) {
    DDRB |= _BV(PORTB2);
    TCCR1A |= _BV(COM1B1);
  setPwmDuty(pin, duty);
  resume();			// Lex - make sure the clock is running.  We don't want to restart the count, in case we are starting the second WGM
					// and the first one is in the middle of a cycle
void TimerOne::disablePwm(char pin)
  if(pin == 1 || pin == 9)       TCCR1A &= ~_BV(COM1A1);   // clear the bit that enables pwm on PB1
  else if(pin == 2 || pin == 10) TCCR1A &= ~_BV(COM1B1);   // clear the bit that enables pwm on PB2
void TimerOne::attachInterrupt(void (*isr)(), long microseconds)
  isrCallback = isr;                                       // register the user's callback with the real ISR
  TIMSK1 = _BV(TOIE1);                                     // sets the timer overflow interrupt enable bit
	// might be running with interrupts disabled (eg inside an ISR), so don't touch the global state
//  sei();
  resume();
void TimerOne::detachInterrupt()
  TIMSK1 &= ~_BV(TOIE1);                                   // clears the timer overflow interrupt enable bit
															// timer continues to count without calling the isr
void TimerOne::resume()				// AR suggested
void TimerOne::restart()		// Depricated - Public interface to start at zero - Lex 10/9/2011
	start();
void TimerOne::start()	// AR addition, renamed by Lex to reflect it's actual role
  unsigned int tcnt1;
  TIMSK1 &= ~_BV(TOIE1);        // AR added
  GTCCR |= _BV(PSRSYNC);   		// AR added - reset prescaler (NB: shared with all 16 bit timers);
  oldSREG = SREG;				// AR - save status register
  cli();						// AR - Disable interrupts
  TCNT1 = 0;
  SREG = oldSREG;          		// AR - Restore status register
	resume();
  do {	// Nothing -- wait until timer moved on from zero - otherwise get a phantom interrupt
	oldSREG = SREG;
	cli();
	tcnt1 = TCNT1;
	SREG = oldSREG;
  } while (tcnt1==0);
//  TIFR1 = 0xff;              		// AR - Clear interrupt flags
//  TIMSK1 = _BV(TOIE1);              // sets the timer overflow interrupt enable bit
void TimerOne::stop()
  TCCR1B &= ~(_BV(CS10) | _BV(CS11) | _BV(CS12));          // clears all clock selects bits
unsigned long TimerOne::read()		//returns the value of the timer in microseconds
{									//rember! phase and freq correct mode counts up to then down again
  	unsigned long tmp;				// AR amended to hold more than 65536 (could be nearly double this)
  	unsigned int tcnt1;				// AR added
	oldSREG= SREG;
  	cli();
  	tmp=TCNT1;
	SREG = oldSREG;
	char scale=0;
	switch (clockSelectBits)
	case 1:// no prescalse
		scale=0;
	case 2:// x8 prescale
		scale=3;
	case 3:// x64
		scale=6;
	case 4:// x256
		scale=8;
	case 5:// x1024
		scale=10;
	do {	// Nothing -- max delay here is ~1023 cycles.  AR modified
		oldSREG = SREG;
		cli();
		tcnt1 = TCNT1;
		SREG = oldSREG;
	} while (tcnt1==tmp); //if the timer has not ticked yet
	//if we are counting down add the top value to how far we have counted down
	tmp = (  (tcnt1>tmp) ? (tmp) : (long)(ICR1-tcnt1)+(long)ICR1  );		// AR amended to add casts and reuse previous TCNT1
	return ((tmp*1000L)/(F_CPU /1000L))<<scale;
#endif
yangkai:
-1 is the default argument(see Default arguments - cppreference.com). So if the second argument is not specified then microseconds is set to -1 and the period is not set, from TimerOne.cpp, line 115:
Can I stop the timer or detachinterrupt() in the interrupt function??
