Hello All,
Bit of a noob on the Arduino side and am trying to emulate the logic I perform on another PLC.
In a nut shell I want to be able to be able to toggle a momentary switch twice (between high and low) within 1 second and take an action
With my existing PLC on input change, when the switch is initially toggled I increment a variable by 1 and start a timer for 1 second. If the the variable hits 2 before the timer rings then the action is taken.
I know I need to use mills() but I just havent got my head around it.
My code works when the input is pressed twice but that could be within 20 seconds or two hours.
I feel I am probably not missing much
If someone could edit my code to poke me in the right direction I would be very grateful. The main void.loop() is where my issue is
//Switch - Clipsal
const int ClipsalPBL = 10; // the number of the pushbutton pin
int buttonState = 0;
int VarHomvisionRollerShedDoor1 = 0;
int buttonPushCounter = 0; // counter for the number of button presses
int lastButtonState = 0; // previous state of the button
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = { 0xAE, 0xFE, 0xDE, 0xEF, 0xFD, 0xFD };
byte gateway[] = { 10, 0, 0, 1 }; //
byte subnet[] = { 255, 255, 255, 0 }; //
IPAddress ip(10,0,0,49);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
#define RELAY_CH1 2
#define RELAY_CH2 3
#define RELAY_CH3 4
#define RELAY_CH4 5
#define RELAY_CH5 6
#define RELAY_CH6 7
#define RELAY_CH7 8
#define RELAY_CH8 9
String readString;
// initialize the pushbutton pin as an input:
pinMode(ClipsalPBL, INPUT);
pinMode(RELAY_CH1, OUTPUT);
digitalWrite(RELAY_CH1, HIGH); // switch on LED1
while (!Serial) {
// start the Ethernet connection and the server:
Ethernet.begin(mac, ip);
server.begin();
Serial.print("HTTP Server has started and is running on IPV4 : ");
Serial.println(Ethernet.localIP());
// read the state of the pushbutton value:
buttonState = digitalRead(ClipsalPBL);
// compare the buttonState to its previous state
if (buttonState != lastButtonState) {
// if the state has changed, increment the counter
if (buttonState == HIGH) {
// if the current state is HIGH then the button went from off to on:
buttonPushCounter++;
Serial.println("on");
Serial.print("Number of button pushes: ");
Serial.println(buttonPushCounter);
// if the current state is LOW then the button went from on to off:
Serial.println("off");
// save the current state as the last state, for next time through the loop
lastButtonState = buttonState;
// turns on the LED every four button pushes by checking the modulo of the
// button push counter. the modulo function gives you the remainder of the
// division of two numbers:
if (buttonPushCounter == 2) {
if (VarHomvisionRollerShedDoor1 == 0){
HomvisionRollerShedDoor1();
VarHomvisionRollerShedDoor1 = 1;
digitalWrite(RELAY_CH1, HIGH); // set pin 4 high
Serial.println("Toggle Relay 1 High");
digitalWrite(RELAY_CH1, LOW); // set pin 4 high
Serial.println("Toggle Relay 1 Low");
HomvisionRollerShedDoor2();
// listen for incoming clients
if (client) {
Serial.println("new client");
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
if (readString.length() < 100) {
//store characters to string
readString += c; //Serial.print(c);
Serial.write(c);
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("Content-Type: text/html");
//client.println("Connection: close"); // the connection will be closed after completion of the response
//client.println("Refresh: 20"); // refresh the page automatically every 5 sec
// control arduino pin via ethernet Start //
if(readString.indexOf("?relay1off") >0)//checks for on
Serial.println("Relay 1 On");
else{
if(readString.indexOf("?relay1on") >0)//checks for off
digitalWrite(RELAY_CH1, LOW); // set pin 4 low
Serial.println("Relay 1 Off");
readString="";
}// if ( c == \n )
if (c == '\n') {
// you're starting a new line
else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
Serial.println("client disonnected");
}//if(Client)
}//Loop
void HomvisionRollerShedDoor1(){
IPAddress server(10,0,0,202);
EthernetClient client2;
if(client2.connect(server,11080)) {
client2.println("GET /?var+44+%3D=111");
client2.println(" HTTP/1.0");
client2.println("User-Agent: Arduino 1.0");
client2.println();
Serial.println("Connect ok");
client2.stop();
client2.flush();
void HomvisionRollerShedDoor2(){
client2.println("GET /?var+44+%3D=222");
client2.println();
client2.stop();
client2.flush();
