I'm trying to control LED lights using an Arduino. I have a PWM output switching a MOSFET which is controlling the LEDs - all good so far.
What I now want to do is dim the LEDs when they are on, so rather than having my PWM output on and off, I want the ON periods to be a PWM signal to dim the LEDs and the OFF to be just off.
I'm using the Timer1 library for my actual LED switching as I find I can get far more accurate periods that way.
I've currently got pin 5 of my Nano and pin 9 with the two frequencies I desire and I'm trying to messily AND them together in hardware before applying the signal to the gate of my MOSFET.
There must be a way to do this in software? I'm not clever enough to know how though.
#include <TimerOne.h>
const int PWMPin = 5; // pin 5 contains the driving PWM signal
const int TogglePin = 9; // d9 is switched for on/off
const int DutyCycle = 255;
pinMode(PWMPin, OUTPUT); // sets the pin as output
analogWrite(PWMPin, 10); // analogWrite values from 0 to 255
Timer1.initialize(250000);
Timer1.pwm(TogglePin,DutyCycle);
You want the leds to flash on and off at a preset frequency and duty cycle and with a preset brightness during the “on” period? This using only one Arduino pin to control the leds ?
Which Arduino board have you?
Can’t you just use the pwm to set the brightness , then switch the analog output on and off with a period set by millis , all on the same pin .
Pseudo code
analogWrite(PWMPin, 10);//turn it on
Delay bit;
analogWrite(PWMPin, 0); // turn it off
…and so on, change the “10,0” for a variable , set it to zero when your on/off switch is operated, set it to a value for brightness.
The solution that @hammy suggested does not block if you use the "Blink without delay" example as a basis:
Blink without Delay
Turns on and off a light emitting diode (LED) connected to a digital pin,
without using the delay() function. This means that other code can run at the
same time without being interrupted by the LED code.
The circuit:
- Use the onboard LED.
- Note: Most Arduinos have an on-board LED you can control. On the UNO, MEGA
and ZERO it is attached to digital pin 13, on MKR1000 on pin 6. LED_BUILTIN
is set to the correct LED pin independent of which board is used.
If you want to know what pin the on-board LED is connected to on your
Arduino model, check the Technical Specs of your board at:
https://www.arduino.cc/en/Main/Products
created 2005
by David A. Mellis
modified 8 Feb 2010
by Paul Stoffregen
modified 11 Nov 2013
by Scott Fitzgerald
modified 9 Jan 2017
by Arturo Guadalupi
This example code is in the public domain.
https://www.arduino.cc/en/Tutorial/BuiltInExamples/BlinkWithoutDelay
// constants won't change. Used here to set a pin number:
const int ledPin = LED_BUILTIN;// the number of the LED pin
// Variables will change:
int ledState = LOW; // ledState used to set the LED
// Generally, you should use "unsigned long" for variables that hold time
// The value will quickly become too large for an int to store
unsigned long previousMillis = 0; // will store last time LED was updated
// constants won't change:
const long interval = 1000; // interval at which to blink (milliseconds)
// set the digital pin as output:
pinMode(ledPin, OUTPUT);
// here is where you'd put code that needs to be running all the time.
// check to see if it's time to blink the LED; that is, if the difference
// between the current time and last time you blinked the LED is bigger than
// the interval at which you want to blink the LED.
if (currentMillis - previousMillis >= interval) {
// save the last time you blinked the LED
// if the LED is off turn it on and vice-versa:
if (ledState == LOW) {
ledState = HIGH;
ledState = LOW;
// set the LED with the ledState of the variable:
digitalWrite(ledPin, ledState);
If you are doing other things in the loop() which may block for a certain time and thus spoil the accuracy of the on/off periods, you can handle the led pin purely through interrupts.
OK that works as it is if the duty cycle of the on/off periods is 50% otherwise, you'd have to choose the period of interrupt carefully and maintain a counter in the ISR.
So, for example, the analogWrite(PWMPin, PWMOnValue); statement is executed when the counter is 0, to switch the LED on, and the analogWrite(PWMPin, PWMOffValue) statement is executed when the counter is 8, to switch the LED off, and the counter is reset to 0 when it reaches 11.
