Timestamp from RTC DS3231
Hi, how can I get time stamp from RTC DS3231? I don't care if it is not classic UNIX but I need time as one data type (ulong). Or do you know about some better solve for programmable alarm clock with DS3231? I tried to use in-build alarms but it was mismatch. Thank you for reply!
Post what you tried and the error message(s)
Which library? With this one https://github.com/JChristensen/DS3232RTC you can simply call RTC.get()
Sorry, it was some time ago and I deleted that code. Thank for that library, and I think I will try this one: https://github.com/sleemanj/DS3231_Simple
how can I get time stamp from RTC DS3231? I don’t care if it is not classic UNIX but I need time as one data type (ulong).
Can you try to build DS3231 Based Clock as per following diagram? The program codes (given below) collects Date and Time from the RTC Chip and shows them on the LCD. And then, you try yourself how to convert the Time string into integer; this is what you are looking for.
#include <Wire.h>     //needed because DS3231 uses I2C Bus
#include <RTClib.h>   //needed becuase we have ready-made functions of this librray
#include<LiquidCrystal_I2C.h>  //neded by LCD
LiquidCrystal_I2C lcd(0x27, 16, 2); //lcd address; 16 characters 2 line
RTC_DS3231 rtc;     //the object rtc is created from the class RTC_DS3231
char daysOfTheWeek[7][4] = {"Sun", "Mon", "Tue", "Wed", "Thu", "Fri", "Sat"};
  lcd.init();
  lcd.backlight();
  lcd.setCursor(0, 0);
  if (! rtc.begin())   //DS3231 is intialized
    while (1);
   rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));//auto update from computer time
   //rtc.adjust(DateTime(2014, 1, 21, 3, 10, 17));//set date-time manualy:yr,mo,dy,hr,mn,se
void  loop()
    //--read Date and Tme from DS3231 using the method now()---------------------;
    //--store the Date and Time into another user define object bamed nowTime
    DateTime nowTime = rtc.now();
    //---show Day and Date on Top Line of LCD--------------
    int x = nowTime.dayOfTheWeek(); //dyOfTheWeek() is a pre-defined method
    lcd.print(daysOfTheWeek[x]);    //days of the Week[] is the user defined array
    lcd.print(": ");
    lcd.print(nowTime.day());
    lcd.print("/");
    lcd.print(nowTime.month());
    lcd.print("/");
    lcd.print(nowTime.year());
    //------show Time on Bottom Line of LCD--------------
    lcd.setCursor(0, 1);
    lcd.print(nowTime.hour());
    lcd.print(":");
    lcd.print(nowTime.minute());
    lcd.print(":");
    lcd.print(nowTime.second());
BTW: Second Field has some bugs; it comes like: 58,59 , 09, 19, …, 99, 10, 11, …57, 58? I have just seen it after submitting the post. Trying to fix it, If it is a library problem, then it will take some time to fix it!!
Alternate Codes that show Time correctly.
#define deviceAddress 0x68
  lcd.init();
  lcd.backlight();
    while (1);
void  loop()
    lcd.print(": ");
    lcd.print("/");
    lcd.print("/");
    lcd.setCursor(8, 1);
    lcd.print(":");
    lcd.print(":");
//void showTimeOnLCD()
  Wire.beginTransmission(deviceAddress); //START, Roll Cal
  Wire.write(0x00); //set SEC Register address
  Wire.endTransmission(); //Execute the above queued data, ACK, STOP
  Wire.requestFrom(deviceAddress, 3);   //SEC, MIN, and HRS to read from RTC as BCD
  byte bcdSeconds = Wire.read();
  byte bcdMinutes = Wire.read();
  byte bcdHours = Wire.read();
  bcdHours = bcdHours & 0b00011111;
   //show HRS--
  lcd.write((bcdHours>>4) + 0x30);
  lcd.write((bcdHours & 0x0F) + 0x30);
  lcd.write(':');
  //show MIN--
  lcd.write((bcdMinutes>>4) + 0x30);
  lcd.write((bcdMinutes & 0x0F) + 0x30);
  lcd.print(':');
 //shiw SEC
 lcd.write((bcdSeconds>>4) + 0x30);
 lcd.write((bcdSeconds & 0x0F) + 0x30);
