Timing Function
Hi All,
I am finding it difficult to find good instructions on writing my own functions. I have had a little success but when i tried to replace delay() with Elapsed timer i can not get it to work.
Any suggestions where i am falling over would be great.
Thanks
#include <Elapsed.h>
const int button = 8;
const int led = 13;
int buttonState = 0;
int pressed = false;
int activate = 0;
  pinMode(button, INPUT);
  pinMode(led, OUTPUT);
static Elapsed t1;
  buttonState = digitalRead(button);
  if (buttonState == LOW)
    int a;
    a = myTimer();
  digitalWrite(led,buttonState);
  //t1.reset();
int myTimer()
  if(!pressed && activate != HIGH)
    activate = HIGH;
    pressed = true;
    t1.reset();
  if(pressed && t1.intervalMs()>5000)
    pressed = false;
    int b;
    b = buttonState;
    if(b == HIGH && a == HIGH)
        b = LOW;
        b = HIGH;
    return b;
Do you mean this?
sketch_may20a.cpp: In function 'int myTimer()':
sketch_may20a:40: error: 'a' was not declared in this scope
What are you trying to do exactly?
No, sorry i forgot to delete that, it does compile with that not there. It was left over from experimenting. I am trying to create a delay before switching on a led, without stopping everything else ( delay () ) At the moment the led just changes state instantly. I tried putting in the code that you originally gave me into my function. It works fine inside the main loop but i have to write it many times over and size is becoming an issue as i use an 88a chip If i can get this to work it will help me to write software the correct way.
Well post the code that compiles.
const int led = 13;
int activate = 0;
static Elapsed t1;
    int a;
    a = myTimer();
  //t1.reset();
int myTimer()
    activate = HIGH;
    pressed = true;
    t1.reset();
    pressed = false;
    int b;
    b = buttonState;
    if(b == HIGH )
        b = LOW;
        b = HIGH;
    return b;
I don’t understand what you want myTimer() to do. It has no side effects and only returns a value that you immediately discard. [edit: nevermind, I see it does have side effects. You’re not using the variables you modify within it elsewhere, though]
You can’t just have a function that “delays without blocking” (blocking = using delay()). You could do it if you wanted to say
if (timeIsUp()) {
  // blink led
Then you could define timeIsUp()
bool timeIsUp() {
  static unsigned long lastFireTime;
  if (millis() - lastFireTime > 1000) {
    lastFireTime += 1000; // or lastFireTime = millis() This version is better since it doesn't drift
    return true;
  return false;
I'm sorry, I'm totally confused by your code.
So confused, that to make it work I would have to just rewrite it.
Try and forget about timers for a minute and think about how you would do this with a watch. Say someone said to you, "10 seconds after you hear a knock on the door, turn on the light". How would you do that?
WizenedEE: You can't just have a function that "delays without blocking" (blocking = using delay()).
Ah I think I see what you are trying to do, thanks to WizenedEE.
No, you can't take the Elapsed library, put it into a function, and call that when you want a delay. You may as well just use delay() if you are going to do that.
All the Elapsed library lets you do is tell how much time elapsed from a "trigger point". So for example, if you start (reset) the timer when the button is pressed, you can check the timer every time around the loop and see how long ago that happened. But you have to do that yourself, it doesn't magically do it for you.
Is this written correctly, keep in mind I am still trying to figure what functions can and can't do. This code needs the button held down but I am not sure why ?
const int led = 13;
  if (buttonState == LOW)// my button is wired backwards
    int a;
    a = myTimer();
int myTimer()
  int b; // flip flop for changing states after time has elapsed
  b = buttonState;
  if(b == HIGH)
    b = LOW;
    b = HIGH;
  delay(2000);
  return b; // not sure if i need this line
Please read (or buy) the excellent book - http://letrongngoc.tech.officelive.com/Documents/TheCProgrammingLanguageSecondEdition.pdf -
Although it is about C it is still one of the better books about programming imho.
And I like this one too - http://www.amazon.com/Computer-Programming-Introduction-Scientifically-Inclined/dp/9081278819
