Timing issue with button press
probably needs an startShow(showType); when you press the button
#include <WS2812FX.h>
#define LED_COUNT 182
#define LED_PIN 6
#define BTN_PIN 2 // the gpio number of the pushbutton
#define TIMER_MS 3000 // cycle effects every 2 seconds
WS2812FX ws2812fx = WS2812FX(LED_COUNT, LED_PIN, NEO_GRB + NEO_KHZ800);
const byte ALLoff = 0;
const byte HIGHLIGHT = 1;
const byte PATRIOTIC = 2;
const byte BREATH = 3;
const byte HOMERUN = 4;
unsigned long last_change = 0;
bool isCycling = false; // flag that enables cycling the effects
byte showType = 0;
void startShow(int i) {
  Serial.println(i);
  switch (i)  {
    case ALLoff:
      ws2812fx.stop();
      ws2812fx.removeActiveSegment(3);
      ws2812fx.removeActiveSegment(2);
      ws2812fx.removeActiveSegment(1);
      ws2812fx.removeActiveSegment(0);
      ws2812fx.start();
      break;
    case HIGHLIGHT:
      ws2812fx.stop();
      ws2812fx.addActiveSegment(0);
      ws2812fx.start();
      break;
    case PATRIOTIC:
      ws2812fx.stop();
      ws2812fx.addActiveSegment(1);
      ws2812fx.start();
      break;
    case BREATH:
      ws2812fx.stop();
      ws2812fx.addActiveSegment(2);
      ws2812fx.start();
      break;
    case HOMERUN:
      ws2812fx.stop();
      ws2812fx.addActiveSegment(3);
      ws2812fx.start();
      break;
  pinMode(BTN_PIN, INPUT_PULLUP); // config BTN_PIN as an input using internal pull-up resistor
  ws2812fx.init();
  ws2812fx.setBrightness(100);
  //from working sketch
  ws2812fx.setIdleSegment(0,  0, 161, FX_MODE_BLINK, COLORS(WHITE, RED), 200, false); // segment 0 is leds 0 - 162 flash (homerun?)
  ws2812fx.setIdleSegment(1, 0, 161, FX_MODE_TRICOLOR_CHASE, COLORS(WHITE, RED, BLUE), 15000, false); // segment 1 is leds 0 - 162 (patriotic)
  ws2812fx.setIdleSegment(2,  0, 161, FX_MODE_BREATH, 0xFF0000, 5000, false); // segment 2 is leds 0 - 162 0xFF0000-RED (breathing)
  ws2812fx.setIdleSegment(3, 162, 184, FX_MODE_COLOR_WIPE, RED, 100, false); // segment 3 is leds (red-circle)
  ws2812fx.strip_off();
  unsigned long now = millis();
  if (!isCycling && digitalRead(BTN_PIN) == LOW)  { // if button pressed, started cycling effects
    last_change = now ;
    showType = 0;
    isCycling = true;
  if (isCycling && (now - last_change > TIMER_MS)) { // go to next animation
    if (++showType > 4) {
      isCycling = false;
      ws2812fx.service();
    else startShow(showType);
    last_change = now;
  if (isCycling)  ws2812fx.service();
that's intended. You press, it starts the animations and then terminates. A new press will start again.
