MorganS:
That is a pretty good example of splitting small elements down into functions.
From what I understand, this should be a compliment, so thank you! I really need some ;o)
MorganS:
I think you've taken the approach a little too far. The second function does almost nothing that the main function doesn't do. You've found the obvious problem that a function can only return one thing but you need to update two variables: the LED status and the timer for that LED. But you're working with a microcontroller, so there's a few shortcuts available to you. The first is to know that you can read an output pin to find out what the current output is. So if you need to change an LED from on to off or off to on, you can:
digitalWrite(local_pin, !digitalRead(local_pin));
So in this way, you don't need to pass the value of led1_status
and the main program can still find out if the LED is on or off by reading it for itself.
You read my mind like a book. ;o)
Really great help! With that tip I could go without my status Variable at all, and I only need one Function!
MorganS:
So why does it "hang"? Well, you're checking the timer in two different places. There will be a time difference between those two places. The technical term for this is "race condition." It depends on exactly when the timer clicks over, if it occurs in between those two checks. Try to write it so that it only checks in one place.
Yeah I thought that should be the problem in some case, but don't know how to handle this.
Thanks for your help!
PaulS:
While not related to your issue, I don't like this:
There is no reason not to use multiple lines for this statement:
prevents the need to scroll code sideways as well as up and down.
How many pins do you have? If it is a standard Arduino, with less then 32,767 pins, a byte is more appropriate to help the pin number. How many states will the pin have? Again, if less then 32,767, use a byte.
Finally, onoff is a dumb name. The pin is on OR off, not both. That value probably should be a boolean. on would then be true. If the value is not true, then the pin is not on.
Fine suggestions! Thank you. I've changed my code as you suggest. The Naming of Variables is a Philosophie Thing I think, but hey you're not wrong. So I take it ;o)
Thanks for your help so far!
Great forum!
My actual Sketch works fine:
//IR Stuff
#include <IRremote.h> //Load Infrarot Library
const long ir_key1 = 16724175; //IR Code Key 1
const long ir_key2 = 16718055; //IR Code Key 2
const long ir_key3 = 16743045; //IR Code Key 3
const int ir_pin = 12;
IRrecv ir_recv(ir_pin);
decode_results ir_results;
//LED1 Stuff
const int led1_pin = 9; //Red LED
const int led1_intervall = 100; //Blink Intervall
boolean led1_blink = LOW; //Blink on/off
unsigned long led1_time;
//LED2 Stuff
const int led2_pin = 10; //Green LED
const int led2_intervall = 500; //Blink Intervall
boolean led2_blink = LOW; //Blink on/off
unsigned long led2_time;
//HALO Stuff
const int halo_pin = 11; //White LED
const int halo_intervall = 1000; //Blink Intervall
boolean halo_blink = LOW; //Blink on/off
unsigned long halo_time;
// IR Stuff
ir_recv.enableIRIn(); // Start the IR Receiver
// LED Stuff
pinMode(led1_pin, OUTPUT);
pinMode(led2_pin, OUTPUT);
pinMode(halo_pin, OUTPUT);
led1_time = millis(); //Safe actual Time in Var
led2_time = millis(); //Safe actual Time in Var
halo_time = millis(); //Safe actual Time in Var
//Check IR Controller for pressed Keys
if(ir_recv.decode(&ir_results)){
//Serial.println(ir_results.value, DEC);
switch(ir_results.value){
case ir_key1:
led1_blink = !led1_blink; //Toggle LED Blink on/off
case ir_key2:
led2_blink = !led2_blink; //Toggle LED Blink on/off
case ir_key3:
halo_blink = !halo_blink; //Toggle LED Blink on/off
ir_recv.resume(); //Check for next pressed Key
//Toggle Red LED Status if Blink is on and Blink Intervall is exceeded
led1_time = blinkfunc(led1_pin, led1_time, led1_blink, led1_intervall);
//Toggle Green LED Status if Blink is on and Blink Intervall is exceeded
led2_time = blinkfunc(led2_pin, led2_time, led2_blink, led2_intervall);
//Toggle White LED Status if Blink is on and Blink Intervall is exceeded
halo_time = blinkfunc(halo_pin, halo_time, halo_blink, halo_intervall);
//LED Blink Function
unsigned long blinkfunc(int local_pin,
unsigned long local_time,
int local_blink,
int local_intervall)
if(local_blink==HIGH){ //Check if Keypad was pressed for on/off
if((millis() - local_time) >= local_intervall){ //Check if Intervall is exceeded
local_time = millis(); //If LED Intervall is exceeded start new one.
digitalWrite(local_pin, !digitalRead(local_pin)); //Toggle LED Status
else{
digitalWrite(local_pin, LOW); //Set LED to off
return local_time; //Return new Timer for checking next turn
Bye,
Mag
