Timing sequence help
Here's my attempt:
const byte RelayCount = 4;
bool ARelayIsOn = false;
const unsigned long SECONDS = 1000UL;
const unsigned long MINUTES = 60 * SECONDS;
struct Relay
  const byte RelayPin;
  unsigned long OnInterval;
  unsigned long OffInterval;
  bool readyToTurnOn;
  bool isOn;
  unsigned long StartTime;
} Relays[RelayCount] =
  {4, 3 * SECONDS, 15 * MINUTES, true, false, 0},
  {5, 3 * SECONDS, 15 * MINUTES, true, false, 0},
  {6, 3 * SECONDS, 15 * MINUTES, true, false, 0},
  {7, 3 * SECONDS, 15 * MINUTES, true, false, 0}
void TurnRelayOn(int r)
  ARelayIsOn = true;
  Relays[r].readyToTurnOn = false;
  Relays[r].isOn = true;
  Relays[r].StartTime = millis();  // Start of OnInterval
  digitalWrite(Relays[r].RelayPin, LOW);  // LOW for ON
void TurnRelayOff(int r)
  ARelayIsOn = false;  // Only one is on at a time
  Relays[r].isOn = false;
  Relays[r].StartTime = millis();  // Start of OffInterval
  digitalWrite(Relays[r].RelayPin, HIGH);  // HIGH for OFF
  for (int r = 0; r < RelayCount; r++)
    pinMode(Relays[r].RelayPin, OUTPUT);
  unsigned long currentMillis = millis();
  if (ARelayIsOn)
    // A relay is on so find the on one and see if it is
    // time to turn off
      if (Relays[r].isOn)
        // See if it is time to
        if (currentMillis - Relays[r].StartTime >= Relays[r].OnInterval)
          // Time to turn off
          TurnRelayOff(r);
  if (!ARelayIsOn)
    // No relay is on so look for one that is ready to turn on
      if (Relays[r].readyToTurnOn)
        TurnRelayOn(r);
        break;  // Don't look for more to turn on!
  // Look for any relay that is off and see if it is ready to turn on
    if (!Relays[r].isOn && !Relays[r].readyToTurnOn)
      if (currentMillis - Relays[r].StartTime >= Relays[r].OffInterval)
        Relays[r].readyToTurnOn = true;
