Timing servo
This sketch runs a servo randomly after the PIR detects motion. Problem is, the motor needs to run five seconds, then stop and wait until new motion is detected. How can I do this?
#include <Servo.h>
#define PIN_SERVO 9
#define MIN_DELAY 130
#define MAX_DELAY 350
Servo servo;
int ledPin = 13; // led connected to control pin 13
int PIRSensor = 3; // the PIR sensor will be plugged at digital pin 2
int state = 0; // variable to store the value read from the sensor pin
int statePin = LOW; // variable used to store the last LED status, to toggle the light
  servo.attach(PIN_SERVO);
pinMode(ledPin, OUTPUT); // declare the ledPin as as OUTPUT
pinMode(PIRSensor, INPUT); // declare the PIRSensor as as OUTPUT
Serial.begin(9600); // use the serial port
state = digitalRead(PIRSensor); // read the sensor and store it in "state"
if (state != 0)
    long msec = random(MIN_DELAY,MAX_DELAY);
    int pos = random(0,181);
    servo.write(pos);
    delay(msec);
digitalWrite(ledPin, HIGH);
Serial.println("Motion Detected!"); // send the string "Motion Detected!" back // to the computer
digitalWrite(ledPin, LOW); // turns light off if motion is not detected
//digitalWrite(
delay(100); // we have to make a delay to avoid overloading the serial port
Why are the comments wrong ... (Usual guess: You tried a number of things already). Means I can't use the rest of the comments, as they may be wrong, too.
OK, to the real question. "The motor needs to run 5 seconds" - the servo will as quickly as it can go to the position you have sent it. Pease explain what you mean by "running for 5 secs" - use 5 seconds to get to that position or wiggle widly for 5 seconds - or some 3rd thing
I am designing a sculpture that will respond (activate motors) to the viewer's presence for five seconds, then stop. Yes, I am combining several sketches. It does run the motor randomly for a moment but not long enough. Thanks.
millis can help you here (compiled, not tested):
static unsigned long StartTime=0;
if (state != 0)
  StartTime=millis();
  while(millis()-StartTime < 5000)
    servo.write(pos);
    delay(msec);
The sketch does compile but now the led/motor runs continually. I have no doubt not included something essential but after playing with it for some time, I can’t resolve the problem.
#include <Servo.h>
#define PIN_SERVO 9
Servo servo;
if (state != 0)
  StartTime=millis();
    servo.write(pos);
    delay(msec);
After checking the wiring, I discovered the ground of the PIR was not connnected. Your sketch works great! Thanks again.
Keith
