Hello, I'm learning all this stuff and need some help.
I have a 12v drill motor that is controlled with a Uno and a BTS7960 bridge driver, it is wired and works.
What I would like to do is have the motor run forwards for 10sec stop for 2sec and reverse for 10sec, stop for 3min then repeat the loop endlessly.
This is the working code I have with the pins.
int r_en = 2;
int l_en = 3;
int r_pwm = 5;
int l_pwm = 6;
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
digitalWrite(r_en, HIGH);
digitalWrite(l_en, HIGH);
analogWrite(r_pwm, 150);
analogWrite(l_pwm, 0);
When you search "arduino pet feeder"... you will find many ideas to set alarms to do things. This example only shows the time and date, so you will want to write code to decide "if the time of day is nine or half-past four, do things."
The code seems to be very random, the 10sec on, 2sec off, 10sec on works but the 180 is very random, I have tested with the U the UL as well as without.
The 180 delays anywhere from 50 sec to 100 sec.
void stop() {
analogWrite(r_pwm, 0);
digitalWrite(r_en, LOW); // disable r motor
digitalWrite(l_en, LOW); // disable l motor
void forward() {
digitalWrite(r_en, HIGH); // enable motor r
digitalWrite(l_en, HIGH); // enable motor l
void reverse() {
analogWrite(l_pwm, 150);
}Use code tags to format code for the forum
When signed variables are made to exceed their maximum or minimum capacity they overflow . The result of an overflow is unpredictable so this should be avoided. A typical symptom of an overflow is the variable "rolling over" from its maximum capacity to its minimum or vice versa, but this is not always the case.
Try an explicit 180000 or 180*1000UL.
// run forwards for 10sec
// stop for 2sec
// reverse for 10sec,
// stop for 3min
// repeat the loop endlessly.
int r_en = 2;
int l_en = 3;
int r_pwm = 5;
int l_pwm = 6;
int seconds_2 = 2;
int seconds_10 = 10;
int seconds_180 = 180; // three minutes
pinMode(r_en, OUTPUT);
pinMode(l_en, OUTPUT);
pinMode(r_pwm, OUTPUT);
pinMode(l_pwm, OUTPUT);
forward();
Serial.print("F(delaying:");Serial.print(10*1000);Serial.print(")");
delay(10 * 1000); // 10 seconds
stop();
Serial.print("S1(delaying:");Serial.print(2*1000);Serial.print(")");
delay(2 * 1000); // 2 seconds
reverse();
Serial.print("R(delaying:");Serial.print(20*1000);Serial.print(")");
delay (10 * 1000);
stop();
Serial.print("S2(delaying:");Serial.print(180*1000);Serial.print(")");
delay (180 * 1000); // 180 seconds = 3 minutes
void stop() {
void forward() {
void reverse() {
I am new to this coding but I find it crazy that a simple code like this is so hard.
In the following code the delay (3 * 60 * 1000); is anywhere from 45sec to 1.5 minutes. It should be 3 min.
// stop for 2sec
// stop for 3min
int r_en = 2;
int l_en = 3;
int r_pwm = 5;
int l_pwm = 6;
forward();
delay(10000);
stop();
delay(2000);
reverse();
delay (10000);
stop();
void stop() {
void forward() {
void reverse() {
Yes, it is possible to control the number of rotations if you have a way of detecting when the drill motor has made a rotation. Some sort of encoder disc and reader will be required.
What is your drill motor turning, and how is it connected? With inertia in the system, can the motor stop turning exactly when you want it without a brake?
So the timing is so random on this that I need to change something.
This motor is turning a tilt bed on a 1940's X-ray machine but with the random timing it wants to run the bed off the rails. I would like to add limit switches so that when the bed goes to far one way it will stop and reverse. Or I guess I could run it till it hits one limit reverses till it hit the next one and stops for 3 min.
