timming a event by arduino
hai i dont know how to write code for calculate time of a event using arduino. i planning to give a square wave input in one pin as soon as the event start ,the arduino has to look for falling edge of the wave to calculate time of the event and store it......is there any other way ...help me :~
Isn't that what pulsein() does?
http://arduino.cc/en/Reference/PulseIn
k.... pulsein vill work onlyt for 3min long pulse, if i want to read pulse longer than 30mins means what to do
For a pulse of that length, just use digitalread and store the time it went high & the time it went low using millis.
hai friends ..for my project i want to calculate the time taken by a task and store it ..again when i signals the microcontroller it should able to do the same takes for the same time....i planned to give a square wave input to the controller as soon as the task starts to calculate time using raising or falling edge of the wave and it is stopped when the task ends. so now i have the time of the task in some register now i have to save it and retrieve it whe i need for this waht i have to use ?? timer1?
if so how to copy the content of the input capture register and save it some place???
is this idea is right or there is any other way????give some codes
:fearful:
// declare your variables, etc.
// all time related events are of type "unsigned long"
eventPinState = 0;
void loop(){
if ( (eventPinState== 0) && (digitalRead(eventPin) ==1){ // event was not started, now it is running
eventPinState = 1;
eventStartTime = millis();
if ( (eventPinState== 1) && (digitalRead(eventPin) ==0){ // event was running, now it is stopped
eventPinState = 0;
eventEndTime = millis();
eventDuration = eventEndTime - eventStartTime;
Serial.print("event duration in mS = ");
Serial.println (eventDuration);
}// end loop
