Tinker Braccio at 360
Hi
At present, default servo motor with T50000 Braccio Robotic ARM support only 180 degree rotation. the Braccio shield works with Arduino UNO.
I wanted to replace with 360 continuous servo motor, but not sure which one are compatible
Also looking at the fitting of Braccio Tinker Robotic ARM, if I can really rotate the Shoulder/Elbow Motos 360 degree
Any advice will be helpful
Regards
Suraj
Do you realise that if you replace the servos with 360 continuous "servo" motors that you will not be able to control their position, only their dotation direction and speed ?
Is that what you want ?
How about Tower Pro MG995 or Tower Pro SG90 ,give it a try!
You are right, that I may not get to control the position, any better way to have both 360 as well as control the position?
as the position is required, else I may have to just check behaviour on the rotation of 360
Thanks Justin, i just checked net , this motors give only 180?
Hi, Another topic is to identify the acceleration ( -16 g to +16g) supported by Robotic ARM servos? how can i check what acceleration (angular) are supported by ARM, can i control the speed, ( it looks like you can only control delay)
Kindly advice
