Tinker CAD simulation question
I was trying to simulate a circuit to control a DC motor with potentiometer in TinkerCAD.
My question is, how accurate is this simulation?
When I connect the motor directly to power and simulate, it shows an RPM of 17568.
But if I try to control is using my circuit (as shown below), the max RPM I get is 9945.
Here is the diagram:
Here is the code for TinkerCAD:
  pinMode(A0, INPUT);
  pinMode(3, OUTPUT);
  analogWrite(3, map(analogRead(A0), 0, 1023, 0, 255));
  delay(10); // Delay a little bit to improve simulation performance
As you have doublechecked that the datasheet of the simulated moter is identical to the datasheet of the motor you use, you have defintly found a bug in TinkerCAD.
No, I am only talking about two different simulations within TinkerCAD, not talking about real motor RPM.
I guess this might be because in once case I was connecting directly to 9V battery to get 17568 simulation, but in other case when powered through Arduino (less power and current), I get less speed in simulation. My bad.
