I was wondering if anyone had any experiance of using tinkerkit dmx sheild with a 30 channel dmx controller.
I have tested the tinkerkit shield with a DMX smoke machine using example code from DMX simple library and it works fine, but when i connect to the 30 channel board it doesn't work. There is a test mode on the 30 channel board and that works and i have tested the controller using the velleman dmx interface which tests every channel and that works as well.
Really stuck, any help or pointers in the right direction would be very much appreciated.
Thanks,
Paul
