I already had a look at Newhaven displays, but all that I've found exceed the size limitations for the assembly. Why do they need to make the boards so much bigger than the displays?
Only need a couple of pins to control those.
That's just a nice to have, not a must have. If there are too many pins, my plan is to use a shift register.
Anyhow, at least in the case of Adafruit, I could prototype with their PCB, and later - for miniaturization - I could just obtain the display component separately from somewhere else.
Thanks! Except for the PCB, this looks very similar to the Adafruit one.
Perhaps do an image search for "oled 128x32". It will give a lot of results.
I wouldn't mind double size and double resolution in all directions. The problem with image search is that I cannot see the physical dimensions. I've tried it already, but I may do so again, perhaps with "oled 256x64".
I have used the Newhaven COG displays in a number of projects with very good results, nice contrast level, low power consumption, fast wakeup from sleep.
The other I like are the C0220 series from Newhaven too and you can use them with or without the plastic mount support (once soldered on board they will not move a bit).
fm:
Thanks for the suggestion!
I suppose by plastic mount support, you mean these little plastic ears. Well, even without them, the board is just a bit too wide, at: 27 mm
Also, I am still hoping for an OLED version. LCD looks so old fashioned. The 128×64 one by Adafruit may actually work when mounted without PCB.
