Tiny tuner trouble.
ATTINY85, using an Ardunio ISP.
I have had a project working on this device, but I would like to calibrate the internal oscillator so I can use a faster baud rate for serial coms.
Cannot get this to work.
I first tried the "interactive serial" Tiny Tuner example, but when i power on the ATTINY the serial terminal receives garbage. I assume this is because the tolerance on my ATTINY is too far out to support 9600bps communication?
So I tried the "Save_To_EEPROM" example.
I have an osciliscope on the "LED" pin, when i send an "x" from the terminal, 9600Baud i see a pulse.
The pulse varies from ~16ms down to 2 or so, in a repeated pattern. The LED never turns fully on indicating the optimum calibration value has been found.
But if i look at the code:
while ( KeepGoing )
    KeepGoing = tt.update();
    for ( uint8_t i=0; i < 2; ++i )
      digitalWrite( PinLED, ! digitalRead( PinLED ) );
      delay( 100 );
It looks like it should be illuminating the LED for ~ 100ms?
I think my code / device is out by a factor of ~ 10?
I have tried the 1Mhz and 8Mhz Tiny core, the result is always the same.
Stay with the interactive sketch. It's easier to troubleshoot with it.
Very likely.
when i send an "x"
How many 'x' characters did you send? Does your terminal application also send line terminators?
Changed back to "interactive" using hyperterminal, holding down the "x" key for a while (minute or so)
About a dozen is enough. Rarely will you need to send more.
What are you using for a USB-to-TTL-serial converter?
FT232RQ
http://www.4dsystems.com.au/prod.php?id=19
Changed to an RS232 - ttl adaptor to try something different.
I have a cro on the RX pin of the adaptor.
When the device powers up I can see a big string of data.
When I press X I can see a few bytes being sent to the PC, these change slightly with each press.
After 15 or so presses a big chunk of data comes back.
Cycle repeats.
On the Arduino terminal it prints about 6 bytes of garbage back for every press of "x".
I think the internal timescale on my ATTINY85 is out of whack by a large margin.
Was playing around with some blink sketches, programmed the 8M bootloader, the 100ms blink was around 100ms.
Try the tiny tuner again and it works :~
Strange. I would swear I have done nothing different this morning from last night. Maybe just needed to sleep on it.
Glad you have it working.
I've been there a few times. :wink:
