I started writing a small and simple XML parser for the Arduino. Currently everything I wrote is in a big sketch file:
#include <ctype.h>
#include <string.h>
//-- Start of the library -------------------------------------------------------------
// Size of the parser-buffer. Make sure no tag is longer than this!
#define BUFFER_SIZE 256
// Maximum number of attributes the parser can handle in one tag
#define ATTR_LEN 10
typedef enum {
IN_TEXT, IN_TAG
ParserState;
typedef struct {
char *name, *val;
NameVal;
class UXMLParser {
private:
char buff[BUFFER_SIZE];
uint16_t buffLen;
ParserState state;
void buffAppend(char c);
void buffClear();
void parseTag();
char* findName(char* p, char* endP, size_t *len);
char* findVal(char* p, size_t *len);
char charBeforeName(char* p);
char charBeforeTagEnd(char* p);
bool isName(char c);
public:
UXMLParser();
void parse(char c);
virtual void handleOpenTag(char *tag, NameVal attr[], uint8_t attrLen) = 0;
virtual void handleCloseTag(char *tag) = 0;
virtual void handleText(char *text) = 0;
UXMLParser::UXMLParser() {
buffClear();
state = IN_TEXT;
void UXMLParser::buffAppend(char c) {
buff[buffLen] = c;
if (buffLen < BUFFER_SIZE) {
buffLen++;
void UXMLParser::buffClear() {
buffLen = 0;
bool UXMLParser::isName(char c) {
return isalnum(c) | c=='.' | c==':' | c=='-' | c=='_';
char* UXMLParser::findName(char* p, char* endP, size_t *len) {
while (p<endP && !isName(*p))
p++; // find start of name
*len = 0;
if (p>=endP) return 0;
while (p+*len < endP && isName(p[*len])) (*len)++; // find end of name
if (p+*len>=endP) return 0;
return p;
char* UXMLParser::findVal(char* p, size_t *len) {
char qmark;
while ((*p)!='"' && (*p)!='\'') p++; // find start of val
qmark = *p;
p++;
*len = 0;
while (p[*len]!=qmark) (*len)++; // find end of val
return p;
char UXMLParser::charBeforeName(char* p) {
while(!isalnum(*p)) {
if (!isspace(*p)) return *p;
p++;
return 0;
char UXMLParser::charBeforeTagEnd(char* p) {
p -= 2;
while(isspace(*p)) {
p--;
return *p;
void UXMLParser::parseTag() {
char *p, *endP, *tag, c;
NameVal attrList[ATTR_LEN];
uint8_t attrP;
bool openTag, closeTag, emptyTag;
size_t len;
p = buff;
endP = buff + buffLen;
p++; // skip the '<'
openTag = true;
closeTag = false;
c = charBeforeName(p);
if (c == '?') return; // skip this tag
if (c == '/') {
openTag = false;
closeTag = true;
c = charBeforeTagEnd(endP);
if (c == '/') {
closeTag = true;
tag = findName(p, endP, &len);
if (tag==0) return;
emptyTag = tag[len] == '>';
tag[len] = 0;
p = tag+len+1;
attrP=0;
if (!emptyTag) {
while (attrP<ATTR_LEN) {
char *attrN, *attrV;
attrN = findName(p, endP, &len);
if (attrN==0) break; // reached end of tag
attrN[len] = 0;
p = attrN+len+1;
attrV = findVal(p, &len);
attrV[len] = 0;
p = attrV+len+1;
attrList[attrP].name = attrN;
attrList[attrP].val = attrV;
attrP++;
if (openTag) handleOpenTag(tag, attrList, attrP);
if (closeTag) handleCloseTag(tag);
void UXMLParser::parse(char c) {
switch (state) {
case IN_TEXT:
if (c=='<') {
buffAppend(0);
handleText(buff);
buffClear();
buffAppend(c);
state = IN_TAG;
else {
buffAppend(c);
case IN_TAG:
if (c=='>') {
buffAppend(c);
parseTag();
buffClear();
state = IN_TEXT;
else {
buffAppend(c);
default:
// -- End of library -----------------------------------------------------------------
// -- Start of test/example program --------------------------------------------------
// UXML uses inheritance, so you have to create your own class,
// and overweite the methods handleOpenTag, handleCloseTag and handleText.
class TestParser : public UXMLParser {
public:
TestParser();
virtual void handleOpenTag(char *tag, NameVal attr[], uint8_t attrLen);
virtual void handleCloseTag(char *tag);
virtual void handleText(char *text);
TestParser::TestParser() : UXMLParser() {
// what should be done, if a tag opens?
void TestParser::handleOpenTag(char *tag, NameVal attr[], uint8_t attrLen) {
Serial.print("handleOpenTag: ");
Serial.print(tag);
for(int i=0; i<attrLen; i++) {
Serial.print(" ");
Serial.print(attr[i].name);
Serial.print("='");
Serial.print(attr[i].val);
Serial.print("'");
// what should be done, if a tag closes?
void TestParser::handleCloseTag(char *tag) {
Serial.print("handleCloseTag: ");
Serial.println(tag);
// what should be done, with text?
void TestParser::handleText(char *text) {
Serial.print("handleText: '");
Serial.print(text);
Serial.println("'");
TestParser testParser = TestParser();
char test[] = "<bc></bc>< a n = 'value' asdf='' jkl=\"'\"> b <emptyTag / >< / a >";
Serial.println("Test started");
// Send the test-string to the parser char by char.
// The parser will call the handle* functions.
for(int i=0; test[i]!=0; i++) {
testParser.parse(test[i]);
Serial.println("Test ended");
// -- End of test/example program --------------------------------------------------
Scroll down to the end to see the test program which parses the XML document "< a n = 'value' asdf='' jkl="'"> b <emptyTag / >< / a >" and prints this:
Test started
handleText: ''
handleOpenTag: bc
handleText: ''
handleCloseTag: bc
handleText: ''
handleOpenTag: a n='value' asdf='' jkl='''
handleText: ' b '
handleOpenTag: emptyTag
handleCloseTag: emptyTag
handleText: ''
handleCloseTag: a
Test ended
I would like to create a library from this. Do you have any suggestions on the interface for this library? For example I am currently using inheritance. Is that OK? An alternative would be function pointers.
I am also working on an Jabber library which will use this parser. However I do not have a Ethernet-Shield yet, so I can't do any testing.
