Tiny45 16MHz external
Tried with fuses:
lfuse:w:0xff:m -U hfuse:w:0xdf:m -U efuse:w:0xff:m
But according to the datasheet it should be:
lfuse:w:0xf0
After programming this value I got:
avrdude: Device signature = 0x000000
avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.
What is wrong ? (HW is ok because I can read or program other T45)
Thanks
potzli:
But according to the dataset it should be:
lfuse:w:0xf0
What "dataset" are you talking about? lfuse:w:0xff looks correct to me:
potzli:
Do you have a crystal connected correctly to the ATtiny45?
pert:
Sorry the the autocorrector put dataset instead of datasheet!!!!
pert:
Yes of course because with lfuse = 0xFF it works. But after check with the fuse calc with 0xF0 it say: "undefined preset 7". I used this one
AVR® Fuse Calculator – The Engbedded Blog . It don't say that is not valid...
potzli:
Would you mind specifying what part of the datasheet made you think 0xf0 is correct? Perhaps break your logic bit by bit.
potzli:
Oh, I see what you're saying now. You mean that it doesn't work with the lfuse:w:0xf0. I thought you were saying that it didn't work with lfuse:w:0xff.
potzli:
http://www.engbedded.com/fusecalc/ . It don't say that is not valid...
"undefined preset 7" essentially does mean that it's not valid.
Datasheet, p.30
CKSEL3:1 = 111
CKSEL0 = 1
SUT1_0 = 0
Seems not impossible (with ceramic crystal) ... Probably I missed something !
Yes it works with 0xFF
The most curious think is why after programming 0xF0 I got:
this check.
I see the problem now. 1 means unprogrammed and 0 means programmed. So in the fuse calculator you need to uncheck the checkboxes for the bits that are set to 1 and check the checkboxes for the bits that are set to 0. You did just the opposite and that's how you got the 0xF0 value.
You're right!! I didn't see this small comment and strange logic!!!
Does it explain why uC are dead (?) after my false fuse programming ?
Is only the issue with a HV programmer to get those uC back to life ?
I don't know how you can recover the chips. I suppose a HV programmer is worth a try. Maybe someone else here will have an answer for this.
Thanks for your help pert !!!
