Tiny85 Low Power
Hello :),
i try to get the lowest consumtion in PowerDown modus:
I turn off the ADC and t all Pins to INPUT LOW
Is there even more i can do to get lower?
This is my code…
// set timer to 0.016s
// WDTCR |= (0<<WDP3) | (0<<WDP2) | (0<<WDP1) | (0<<WDP0);
// set timer to 0.032s
// WDTCR |= (0<<WDP3) | (0<<WDP2) | (0<<WDP1) | (1<<WDP0);
// set timer to 0.064s
// WDTCR |= (0<<WDP3) | (0<<WDP2) | (1<<WDP1) | (0<<WDP0);
// set timer to 0.125s
// WDTCR |= (0<<WDP3) | (0<<WDP2) | (1<<WDP1) | (1<<WDP0);
// set timer to 0.250s
// WDTCR |= (0<<WDP3) | (1<<WDP2) | (0<<WDP1) | (0<<WDP0);
// set timer to 0.5s
// WDTCR |= (0<<WDP3) | (1<<WDP2) | (0<<WDP1) | (1<<WDP0);
//set timer to 1 sec
//WDTCR |= (0 << WDP3) | (1 << WDP2) | (1 << WDP1) | (0 << WDP0);
//set timer to 2 sec
//WDTCR |= (0<<WDP3) | (1<<WDP2) | (1<<WDP1) | (1<<WDP0);
//set timer to 4 sec
//WDTCR |= (1<<WDP3) | (0<<WDP2) | (0<<WDP1) | (0<<WDP0);
//set timer to 8 sec
//WDTCR |= (1<<WDP3) | (0<<WDP2) | (0<<WDP1) | (0<<WDP1);
#include <avr/interrupt.h>
#include <avr/sleep.h>
byte power_counter = 0;
byte adc_counter = 0;
int adc_in = 1024;
ISR(WDT_vect) {
  power_counter++;
  adc_counter++;
  WDTCR |= (1 << WDP3) | (0 << WDP2) | (0 << WDP1) | (0 << WDP0);
  // Set watchdog timer in interrupt mode
  WDTCR |= (1 << WDIE);
  WDTCR |= (0 << WDE);
  sei(); // Enable global interrupts
  set_sleep_mode(SLEEP_MODE_PWR_DOWN);
  power_off();
  if (power_counter > 0) {
    power_counter = 0;
    adc_in = read_LDR();
    if (adc_in > 30) { //Higher Value = Darker
      pinMode(PB0, OUTPUT);
      pinMode(PB1, OUTPUT);
      pinMode(PB4, OUTPUT);
      digitalWrite(PB0, HIGH);
      digitalWrite(PB1, HIGH);
      digitalWrite(PB4, HIGH);
      delay(250);
int read_LDR(void)
  int adc_val = 0;
  //enable pullup on ADC Pin
  pinMode(PB2, INPUT);
  digitalWrite(PB2, HIGH);
  // Set the ADC input to PB2/ADC1
  ADMUX |= (1 << MUX0);
  ADMUX |= (1 << ADLAR);
  // Set the prescaler to clock/128 & enable ADC
  ADCSRA |= (1 << ADPS1) | (1 << ADPS0) | (1 << ADEN);
  for (byte i = 0; i < 3; i++) {
    // Start the conversion
    ADCSRA |= (1 << ADSC);
    // Wait for it to finish
    while (ADCSRA & (1 << ADSC));
    adc_val += ADCH;
  return adc_val / 3;
void power_off() {
  pinMode(PB0, INPUT);
  pinMode(PB1, INPUT);
  pinMode(PB3, INPUT);
  pinMode(PB4, INPUT);
  digitalWrite(PB0, LOW);
  digitalWrite(PB1, LOW);
  digitalWrite(PB2, LOW);
  digitalWrite(PB3, LOW);
  digitalWrite(PB4, LOW);
  ADCSRA &= ~(1 << ADEN);   //Turn off ADC
  ACSR |= _BV(ACD);         //Disable analog comparator
  sleep_mode();             //Go Sleep
Many of the tips in this excellent tutorial apply to ATTinys.
For that matter, low power operation with the ATMega328 is so good that there is really no reason to use an ATTiny.
jremington: Many of the tips in this excellent tutorial apply to ATTinys.
Really nice tutorial.
The size and the costs are the reasons.
